Help for Mac user
pjano
I am using Octane on a mac. I know, no ideal but what can You do. I recently am experiencing a lot of crashes and I suspect two things, so that is why I am calling out any Mac users for advice and possible help.
I am using an Imac on High Sierra 10.13.6 a GTX 1080 Ti on a Tb3 external enclosure.
My Nvidia Drivers: Gpu WebDriver is 387.10.10.10.40.105
Cuda: 410.130
Octane plugin is 2019 1.5 R3
The installation guide only shows the Windows option so my first question is: where did You install the Plugin? I installed mine in User/username/Library/Preferences/Maxon/Maxon Cinema 4d R21/plugins. But maybe that is causing the problem?
Also, what is the latest Nvidia Webdriver and Cuda that is stable and safe to use?
Before I continue to investigate my issues further I want to get those two things out of the way.
I hope that someone can help me out here.
Thank You
Piotr
iMac (Retina 5K, 27-inch, 2017)
4,2 GHz Quad-Core Intel Core i7
40 GB 2400 MHz DDR4
Radeon RX 5700 XT (external GPU Akitio Node)
David_S
Try to install in a folder named «plugins» on the same level as the application is.
Did you delete all other versions except R21 in the octane plugin folder?
best
David
Hi Piotr,
from what you have written, everything seems in order.
Please, go to c4d menu Extensions Console, (Shift+F10), and share a complete screenshot of the panel, thanks.
Please, also share a screenshot like this one:
ciao Beppe
pjano
Hi!
Thank You for the suggestion.
Here are the screenshots
Screen Shot 2020-03-20 at 13.14.01.png (28.44 KiB) Viewed 2646 times
40 GB 2400 MHz DDR4
pjano
So I changed the install directory to the Application folder but the problem persists. After a while of working I get the spinning ball and at the bottom left corner of the C4d Window I can see:" Octane: RESET PROJECT"
Thank You
Piotr
40 GB 2400 MHz DDR4
pjano wrote:So I changed the install directory to the Application folder but the problem persists. After a while of working I get the spinning ball and at the bottom left corner of the C4d Window I can see:" Octane: RESET PROJECT"
Thank You
Piotr
It's a message what you can see when you send a render or stop render. What's the steps to see that? Did it happen as you start a render?
Also you mention about crashes, how do you know it's crashed? If crashed you should have some bugreport.zip files. Please post here.
Also send "c4doctanelog.txt" then activate all log output flags and try until crash/hang happened and again send "c4doctanelog.txt"
pjano
Actually it is not crashing but freezes indefinitely. It happens often when I try to load an image texture.
Thank You
Piotr
40 GB 2400 MHz DDR4
pjano wrote:Actually it is not crashing but freezes indefinitely. It happens often when I try to load an image texture.
Thank You
Piotr
then please activate all log output flags and try until crash/hang happened and again send "c4doctanelog.txt"
as I wrote above
pjano
Here it is
c4doctanelog.txt
(4.31 KiB) Downloaded 150 times
40 GB 2400 MHz DDR4
pjano wrote:Here it is
log output doesn't cover much information. Just a few lines. Can you explain what happened when you take this file?
