You should try latest 2020.1. And contact to support if your problem persist.rclassenphoto wrote:so people, the problem is found. Octane cannot process the normal noise and then gets stuck! Please solve the problem.
Cinema 4D version 2019.1.5-R3 (Obsolete stable) 12.02.2020
- rclassenphoto
ok so you don´t work on 2019 anymore? Can you please post links to 2020 Octane version, octane network render and c4d verion of 2020?
I work, It will most likely get update if 2020.1 doesn't enter to stable stage before I complete current works. You can find the links just above to this topic.rclassenphoto wrote:ok so you don´t work on 2019 anymore? Can you please post links to 2020 Octane version, octane network render and c4d verion of 2020?
- blackcat321
我的Octane Local DB有一个问题,纹理路径未加载到其中。当我探索路径时,目录是正确的,但是必须有一种方法来修复它,以免我重新加载每个纹理。
使用Octane 20191.5-R3
使用Octane 20191.5-R3
- rclassenphoto
aoktar wrote:I work, It will most likely get update if 2020.1 doesn't enter to stable stage before I complete current works. You can find the links just above to this topic.rclassenphoto wrote:ok so you don´t work on 2019 anymore? Can you please post links to 2020 Octane version, octane network render and c4d verion of 2020?
hi, how can i send you a scene file? thx
Heya, I have a request about collecting image texture sequences when are animated. Octane seems to ignore this, only c4d native materials collect everything.
This gave me headaches as i was working on a massive scene with many many animated sequences, while same time i was trading this scene with other artists daily. So i couldnt be organised as i wanted and i had image sequences all over my hard drive. And every time i had to send the file, i had to collect manually everything, something which proved very time consuming.
Is there a way to add /fix this issue?
thanks a lot
thanks a lot
For custom shaders(ImageTexture), programmer should add own methods to collect used assets. So I have to write some functionality to provide this.thanulee wrote:Heya, I have a request about collecting image texture sequences when are animated. Octane seems to ignore this, only c4d native materials collect everything.
thanks a lot
Yes please! Its really important utility feature
Thanks so much
Thanks so much
- rclassenphoto
So here in octane 2019 the same error shit again.....
Here is the log file:
[2020-03-29 00:39:19][1] Register OctaneLive
[2020-03-29 00:39:19][0] Loaded Octane DLL:OctaneRender Enterprise 2019.1.5 version:6000500 SDK:2019.1.5
[2020-03-29 00:39:19][0] Octane Render for Cinema 4D 2019.1.5-R3 built for:210 C4D vers:21207
[2020-03-29 00:39:19][0] C4D:21207 comp:[Workstation] OS:[WINDOWS 64 BIT] Windows 10, 64 Bit, Professional Edition (build 18363) opengl:460 versType:10
[2020-03-29 00:39:19][0] CPU:[AuthenticAMD, stepping 1, model 1, instruction family 15] speed:4 GHz numOfCpu:32Ht
[2020-03-29 00:39:19][0] Plugins:[houdiniconfig 3dquakersR21 addons advanced render alembic archigrass bitmapfilter bpexchange browser bugslife_client c4dOctane-R21 ca ca2 cadexchange clothilde collada14 collada15 colorchoosergui compositing deployment dwg dwgobjects dynamics exchanges expressiontag fbx Forester1ExpansionPack1R21 ForesterR21 gpurenderer hair HDRI Browser R21 HDRI Link R21 hot4dr21 i_skp io_obj metrics mkmodeler mocca model mograph motioncam motiontracker nbp newman nodeeditor_material objects onlineupdater projectassetinspector python relaxuv sculpt sculptbrushes shader sketch sky sla spacemouse substance teamrender thinking particles tpoperators TurbulenceFD_R21_1452 uvviewport volumes walkthrough X-Particles_21 xpressocore xtensions ]
[2020-03-29 00:39:19][0] NVAPI initializing...
[2020-03-29 00:39:20][0] NVAPI Version: NVidia Complete Version 1.10
[2020-03-29 00:39:20][0] Nvidia driver version:442.74 [r442_70]
[2020-03-29 00:39:20][1] LoadOslScripts()
[2020-03-29 00:39:20][0] Loaded 173 osl scripts from dir:C:\Program Files\Maxon Cinema 4D R21\plugins\c4doctane\res\osl_scripts
[2020-03-29 00:39:20][1] LoadCustomLuts()
[2020-03-29 00:39:27][1] <markMaterials>
[2020-03-29 00:39:27][1] RestoreLayout(secret=fdefc550)
[2020-03-29 00:39:27][1] InitFromRestoreLayout
[2020-03-29 00:39:27][1] setResFromRndSettings 0x0000012754F6FE40 [OK]
[2020-03-29 00:39:27][1] initOctaneLive()
[2020-03-29 00:39:27][1] Init OctaneLive...[2020-03-29 00:39:28][1] Plugin initialized.[2020-03-29 00:39:28][1] Plugin activation...[2020-03-29 00:39:32][1] Plugin activation OK.[2020-03-29 00:39:32][1] Activation time=4.752 sec.
[2020-03-29 00:39:32][0] readDeviceSettings E:01 P:01 T:01 D:01
[2020-03-29 00:39:32][0] VRAM used/free/max:0Kb/24Gb/24Gb Out-of-core used:0Kb RAM used:10.375Gb total:127.871Gb OpenGL free/total:0/0
[2020-03-29 00:39:32][1] Device:0 [TITAN RTX]<Dis>[PT][7.5] Memory used/free/total:0Kb/24Gb/24Gb outOfCoreMem:0Kb p2pBytesUsed:0 runtimeDataSize:0Kb temperature:41
[2020-03-29 00:39:32][1] Device:1 [TITAN RTX]<Dis>[PT][7.5] Memory used/free/total:0Kb/24Gb/24Gb outOfCoreMem:0Kb p2pBytesUsed:0 runtimeDataSize:0Kb temperature:45
[2020-03-29 00:39:32][1] setInteractive(1)[OK] [2020-03-29 00:39:32][1] readPrmsFrScn(1)
[2020-03-29 00:39:32][1] processRegions()
[2020-03-29 00:39:32][1] ApiUpdate Wait:0 Caller:needApiUpdate tm:4.045ms. [OK]
[2020-03-29 00:39:32][1] setExportStatus(st=9, flg=0, thr=0)
[2020-03-29 00:39:32][1] ApiUpdate Wait:0 Caller:needApiUpdate tm:4.668ms. [OK]
[2020-03-29 00:39:48][1] checkNewVersions()
[2020-03-29 00:39:48][1] resetOrbxRootGraphs()
[2020-03-29 00:39:48][1] readPrmsFrScn(0)
[2020-03-29 00:39:48][1] readPrmsFrScn(1)
[2020-03-29 00:39:48][1] readPrmsBC 11111[2020-03-29 00:39:49][0] restoreDeviceStates status:2
[2020-03-29 00:39:49][0] setDevicesActivity rDevices:01 nDevices:01
[2020-03-29 00:39:49][0] save
[2020-03-29 00:40:10][0] AllDevicesOff
[2020-03-29 00:40:13][0] AllDevicesOff
[2020-03-29 00:40:13][0] restoreDeviceStates status:4
[2020-03-29 00:40:13][0] setDevicesActivity rDevices:01 nDevices:01
[2020-03-29 00:40:13][0] save
- rclassenphoto
Now i have installed a new windows update KB4541335 now it works! Amazing
