Cinema 4D version 2019.1.5-R3 (Obsolete stable) 12.02.2020
rclassenphoto wrote:so people, the problem is found. Octane cannot process the normal noise and then gets stuck! Please solve the problem.
You should try latest 2020.1. And contact to support if your problem persist.
rclassenphoto
ok so you don´t work on 2019 anymore? Can you please post links to 2020 Octane version, octane network render and c4d verion of 2020?
rclassenphoto wrote:ok so you don´t work on 2019 anymore? Can you please post links to 2020 Octane version, octane network render and c4d verion of 2020?
I work, It will most likely get update if 2020.1 doesn't enter to stable stage before I complete current works. You can find the links just above to this topic.
blackcat321
我的Octane Local DB有一个问题,纹理路径未加载到其中。当我探索路径时,目录是正确的,但是必须有一种方法来修复它,以免我重新加载每个纹理。
使用Octane 20191.5-R3
rclassenphoto
hi, how can i send you a scene file? thx
thanulee
Heya, I have a request about collecting image texture sequences when are animated. Octane seems to ignore this, only c4d native materials collect everything.
This gave me headaches as i was working on a massive scene with many many animated sequences, while same time i was trading this scene with other artists daily. So i couldnt be organised as i wanted and i had image sequences all over my hard drive. And every time i had to send the file, i had to collect manually everything, something which proved very time consuming.
Is there a way to add /fix this issue?
thanks a lot
thanulee wrote:Heya, I have a request about collecting image texture sequences when are animated. Octane seems to ignore this, only c4d native materials collect everything.
thanks a lot
For custom shaders(ImageTexture), programmer should add own methods to collect used assets. So I have to write some functionality to provide this.
thanulee
Yes please! Its really important utility feature :)
Thanks so much
rclassenphoto
So here in octane 2019 the same error shit again.....
Here is the log file:
[2020-03-29 00:39:19][1] Register OctaneLive
[2020-03-29 00:39:19][0] Loaded Octane DLL:OctaneRender Enterprise 2019.1.5 version:6000500 SDK:2019.1.5
[2020-03-29 00:39:19][0] Octane Render for Cinema 4D 2019.1.5-R3 built for:210 C4D vers:21207
[2020-03-29 00:39:19][0] C4D:21207 comp:[Workstation] OS:[WINDOWS 64 BIT] Windows 10, 64 Bit, Professional Edition (build 18363) opengl:460 versType:10
[2020-03-29 00:39:19][0] CPU:[AuthenticAMD, stepping 1, model 1, instruction family 15] speed:4 GHz numOfCpu:32Ht
[2020-03-29 00:39:19][0] Plugins:[houdiniconfig 3dquakersR21 addons advanced render alembic archigrass bitmapfilter bpexchange browser bugslife_client c4dOctane-R21 ca ca2 cadexchange clothilde collada14 collada15 colorchoosergui compositing deployment dwg dwgobjects dynamics exchanges expressiontag fbx Forester1ExpansionPack1R21 ForesterR21 gpurenderer hair HDRI Browser R21 HDRI Link R21 hot4dr21 i_skp io_obj metrics mkmodeler mocca model mograph motioncam motiontracker nbp newman nodeeditor_material objects onlineupdater projectassetinspector python relaxuv sculpt sculptbrushes shader sketch sky sla spacemouse substance teamrender thinking particles tpoperators TurbulenceFD_R21_1452 uvviewport volumes walkthrough X-Particles_21 xpressocore xtensions ]
[2020-03-29 00:39:19][0] NVAPI initializing...
[2020-03-29 00:39:20][0] NVAPI Version: NVidia Complete Version 1.10
[2020-03-29 00:39:20][0] Nvidia driver version:442.74 [r442_70]
[2020-03-29 00:39:20][1] LoadOslScripts()
[2020-03-29 00:39:20][0] Loaded 173 osl scripts from dir:C:\Program Files\Maxon Cinema 4D R21\plugins\c4doctane\res\osl_scripts
[2020-03-29 00:39:20][1] LoadCustomLuts()
[2020-03-29 00:39:27][1] <markMaterials>
[2020-03-29 00:39:27][1] RestoreLayout(secret=fdefc550)
[2020-03-29 00:39:27][1] InitFromRestoreLayout
[2020-03-29 00:39:27][1] setResFromRndSettings 0x0000012754F6FE40 [OK]
[2020-03-29 00:39:27][1] initOctaneLive()
[2020-03-29 00:39:27][1] Init OctaneLive...[2020-03-29 00:39:28][1] Plugin initialized.[2020-03-29 00:39:28][1] Plugin activation...[2020-03-29 00:39:32][1] Plugin activation OK.[2020-03-29 00:39:32][1] Activation time=4.752 sec.
[2020-03-29 00:39:32][0] readDeviceSettings E:01 P:01 T:01 D:01
[2020-03-29 00:39:32][0] VRAM used/free/max:0Kb/24Gb/24Gb Out-of-core used:0Kb RAM used:10.375Gb total:127.871Gb OpenGL free/total:0/0
[2020-03-29 00:39:32][1] Device:0 [TITAN RTX]<Dis>[PT][7.5] Memory used/free/total:0Kb/24Gb/24Gb outOfCoreMem:0Kb p2pBytesUsed:0 runtimeDataSize:0Kb temperature:41
[2020-03-29 00:39:32][1] Device:1 [TITAN RTX]<Dis>[PT][7.5] Memory used/free/total:0Kb/24Gb/24Gb outOfCoreMem:0Kb p2pBytesUsed:0 runtimeDataSize:0Kb temperature:45
[2020-03-29 00:39:32][1] setInteractive(1)[OK] [2020-03-29 00:39:32][1] readPrmsFrScn(1)
[2020-03-29 00:39:32][1] processRegions()
[2020-03-29 00:39:32][1] ApiUpdate Wait:0 Caller:needApiUpdate tm:4.045ms. [OK]
[2020-03-29 00:39:32][1] setExportStatus(st=9, flg=0, thr=0)
[2020-03-29 00:39:32][1] ApiUpdate Wait:0 Caller:needApiUpdate tm:4.668ms. [OK]
[2020-03-29 00:39:48][1] checkNewVersions()
[2020-03-29 00:39:48][1] resetOrbxRootGraphs()
[2020-03-29 00:39:48][1] readPrmsFrScn(0)
[2020-03-29 00:39:48][1] readPrmsFrScn(1)
[2020-03-29 00:39:48][1] readPrmsBC 11111[2020-03-29 00:39:49][0] restoreDeviceStates status:2
[2020-03-29 00:39:49][0] setDevicesActivity rDevices:01 nDevices:01
[2020-03-29 00:39:49][0] save
[2020-03-29 00:40:10][0] AllDevicesOff
[2020-03-29 00:40:13][0] AllDevicesOff
[2020-03-29 00:40:13][0] restoreDeviceStates status:4
[2020-03-29 00:40:13][0] setDevicesActivity rDevices:01 nDevices:01
[2020-03-29 00:40:13][0] save
rclassenphoto
Now i have installed a new windows update KB4541335 now it works! Amazing :-D
Return to “Releases”
