Cinema4D version 2020.1-RC1[R2] (ReleaseCandidate)29.02.2020
pxlntwrk
aoktar wrote:It's about some extra work on node editor to prepare structure for an incoming feature. I will bring a newer build to fix it.
Thank you for making us part , because it's something that can make you crazy ! :shock: :lol:
pxlntwrk.net
VVG
aoktar wrote:
Kalua wrote:Thank you, Aoktar!
So far is really nice!
One question: how do you access the Spectron area/sphere primitives featured in 2020.1?
PS2: I think I found the primitive feature.
1- Thanks I forgot it to fix, next time I hope
2- Limited to sphere or plane
Explain how to use it in C4D (Spectron area/sphere primitives )
thanks
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
thanks
Just activate "Use primitives" parameter in Octane light tag.
Published a quick fix with the newer build(2020.1-RC1-R2). Ability to make groups for nodes added. It's experimental WIP features. Be careful until finished.
VVG
aoktar wrote: Just activate "Use primitives" parameter in Octane light tag.
Yes I know. The difference is soooo small. At large sample values > 100
thx
ps
name topic Cinema 4D version 2020.1-RC1 (Release candidate) 29.02.2020, need fix
thx
Yes I know, we're working on to fix it. It's about how I created the nodetree for primitive lights. It doesn't love the common way that I used for lights.
Anyway it's still giving good results, I may be wrong for my decision about it. Check pictures, AI light should be activated as I can get it.
pxlntwrk
aoktar wrote:Published a quick fix with the newer build(2020.1-RC1-R2). Ability to make groups for nodes added. It's experimental WIP features. Be careful until finished.
Marvelous, you make my day !
Super happy to finally see this feature arrive :D ;)
pxlntwrk.net
mojave
divasoft wrote:
mojave wrote:
divasoft wrote:+1 i confirm this problem.
Could you export an ORBX that shows the issue and share it with us? Thank you.
Problem appear when RTX is on AND accurate Round edges in material is on too. I will send orbx to pm.
Thank you for sharing your scene. Just confirming this issue will be solved in the next core 2020.1 RC2 release.
VVG
thx
In the cloner you have a light source sphere (C4D light settings)?
SSmolak
In Octane Standalone ( 2020.1 RC1 ) Hosek&Wilkie Sky model has very soft, nice transition between sky and ground. In C4D there is very harsh unnatural transition. Can you repair this ?
Return to “Releases”
