Cinema4D version 2020.1-RC1[R2] (ReleaseCandidate)29.02.2020
Hi all,
This is the build of the plugin with first release candidate of 2020.1-RC1 SDK. This means that this release contains all features planned for the stable build once it is released but we may still go through more iterations to solve any issues as required. Please be aware this is still not a stable release so please do not use this for production purposes Any feedbacks are welcome for development and fixing the issues. Enjoy it!
This is the matching Standalone: OctaneRender™ 2020.1-RC1.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also, make sure you use a driver of version 419.xx or higher and if you are working on Mac OS that has a CUDA driver installed that supports at least CUDA 9.1.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Do a clean install while doing this to be sure previous files completely removed.
Changes of 2020.1-RC1-[R2] plugin
- Fix for wrong connections with nodes on the previous build(2020.1-RC1).
- WIP addon for grouping feature for Octane nodes. It's still in development and do not trust it for commercial projects.
Changes of 2020.1-RC1 plugin
- Added new "Generate log report" button under Settings/Other/Log section. Use it when you'll make bugreports. Also, be sure the required log options are checked for the scene before that.
- Minor fixes
  • Improved out-of-core and peer-to-peer (NVlink) so data that would always need to be on VRAM before can now be evicted. This means that some scenes that would run out of VRAM may work now.
  • Improved importing vertex attributes from Alembic data enforcing some restraints that avoid loading corrupt data.
Bugfixes:
  • Fixed dirt texture does rendering black with RTX geometry.
  • Fixed accurate rounded edges mode not being applied on RTX geometry.
  • Fixed GPU illegal memory access when using emission and RTX with animated instances.
  • Fixed a device error happening sometimes when using more than one RTX meshes.
  • Fixed some cases causing the render to hang without producing any output.
  • Fixed wrong license expiry time being displayed when activating subscription builds using a perpetual license.
  • Fixed issue with auto bump map calculation causing the output to be black in some scenarios.
  • Fixed issue with auto bump was not working as intended when the object was scaled or rotated.
  • Fixed issue with camera focus picker which did not work when using a universal camera in thin lens mode with astigmatism not set to zero.
  • Fixed issue reloading OCS files which would contain dynamic pins which names would not show up.
  • Fixed crash when switching denoiser on/off and device peering was enabled.
WINDOWS ENTERPRISE BUILD (R15-R21)
https://render.otoy.com/customerdownloa ... R2_win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-R21)
OSX ENTERPRISE BUILD (R15-R21)
https://render.otoy.com/customerdownloa ... Macosx.zip
OSX SUBSCRIPTION(Studio) BUILD (R15-R21)
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 435.80) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
-Cuda 9.1 driver for OSX.
ONLINE HELP MANUAL
To use OFFLINE version of manual from plugin
Download following package and extract to Cinema4D/plugins/c4doctane/manual
https://render.otoy.com/plugindownloads ... p-html.zip
V3 SAMPLE SCENES SET(make a request if you need any specific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Cinema 4D Release 20: c4dOctane-r20.xdl64 or c4doctane_R20_demo.xlib
Cinema 4D Release 21: c4dOctane-r21.xdl64 or c4doctane_R21_demo.xlib
divasoft
Hi. I just want to remind about particles motion blur problem which persist for many years.
If scene consist a huge amount of particles with enabled motion blure, MB calculation time increasing frame by frame even if amount of particles is constant.
And if restart render MB calculation time significantly reduced FOR SAME FRAME and start to increase again.
This problem makes it impossible to render a huge number of particles.
I write about this problem 6 times - no reaction. The problem is in any scene with a huge number of particles of about 1,000,000.
divasoft wrote:Hi. I just want to remind about particles motion blur problem which persist for many years.
I know the topic and pretty sure this is answered to somebody else in the past several times. Btw there's no magical solution to apply. The case is about having rapidly increased numbers of data underhood and requirement of more calculation after some frames. Restarting the frames that clear the data but this cannot be applied by plugin because it cannot be sure it's safely appliable for every case. But you can try to use less cached frames for motionblur from object tag.
divasoft
bepeg4d wrote:Hi divasoft,
have you tried this solution?
viewtopic.php?f=30&t=63829&start=10#p371203
ciao Beppe
sorry, was not helpful.
Kalua
Thank you, Aoktar!
So far is really nice!
One question: how do you access the Spectron area/sphere primitives featured in 2020.1?
PS1: small bug I just found: It seems your node display filter in the node editor is not working 100% (see picture)
PS2: I think I found the primitive feature.
PS2: Does this correspond to the Spectron primitives? Will only work with square and sphere shapes for now right?
PS: small bug I just found: It seems your node display filter in the node editor is not working 100%
C4D 2025.3.3 Octane v1.9.4 // Octane SA 2026.4, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
divasoft
I trust you, but you speak about it as phisical limitation like gravity whose imposible to eliminate, but it just an algorithm. In RS it works nice and i have heard in octane for houdini it works perfect too.
Anyway, RS developers have solved this problem. So it’s possible to do it. I believe that you have enough experience to do this.
Every software has different possibilities, somethings are easier or harder to obtain. It's a design matter. This is not on a priority on my list, having different things before that. Motion processor is compicated part and xparticles is a pain to integrate.
handsomeninja
Material previews don't work in Redshift when you're running ipr. Each team has its priorities.
AaronWestwood
Is there any rough time estimate when we could expect a stable release? (no rush, just wondered)
So excited to get this running in the workflow :)
3D Environment Artist
http://www.artstation.com/aaronwestwood
2 x 4090 // 13900KS // 96GB 5600mHz DDR5 // Windows 11
