Octane crashes
misi
Octane is crashing a lot. I cannot start my render. Wonder why?
Bug report attached.
_BugReport.zip
(91.25 KiB) Downloaded 192 times
Seems a crash on octane.dll. I've written the steps to follow in crash situations. Did you see in release notes and apply?
Idonee
Hello. It also happens to me often, due to textures. Moreover, crashes have a chaotic order, the octane can read the texture and then start to crash because of it. Saves if you understand what kind of texture and re-save with a different bit in a different format. Sometimes up to 50-80 crashes per day, with a constant search for textures that this time did not like. Already somehow wrote about the problem on the forum, but then no solution was found. Those. the problem for about a year exists has become very aggravated in the last 3 release versions. I tried to install other drivers, roll back, install the studio version - nothing helps.
It seems that the problem is rare so it is not a fact that a solution will be found. But still, if there is an opportunity to devote time to this, I would be very grateful, because I’m very pleased with the octane as a whole, but recently the number of crashes is not compatible with at least some productive work.
Idonee wrote:Hello. It also happens to me often, due to textures. Moreover, crashes have a chaotic order, the octane can read the texture and then start to crash because of it. Saves if you understand what kind of texture and re-save with a different bit in a different format. Sometimes up to 50-80 crashes per day, with a constant search for textures that this time did not like. Already somehow wrote about the problem on the forum, but then no solution was found. Those. the problem for about a year exists has become very aggravated in the last 3 release versions. I tried to install other drivers, roll back, install the studio version - nothing helps.
Version? Also could you please send a few bugreports and c4doctanelog.txt?
Idonee
cinema 4d r19, octane 2019.1.5 (and it was same issue in last 3 stable releases) the current driver is 442.19 (but as I already said the problem has existed for about a year, so there were different versions of drivers) right now I'm trying to fix the project from crashes, I can show it on Skype, or in any messenger where you can show the screen. I apply what is written in the octane log during an error.
is this enough or more information is needed? I will provide everything you need
upd
same issue in Cinema 4D R21, just test it
c4doctanelog.txt
(3.18 KiB) Downloaded 248 times
_BugReport.txt
(378.58 KiB) Downloaded 192 times
_BugReport.txt
(617.03 KiB) Downloaded 268 times
please, deactivate all the octane licenses, then upgrade win 10 to 1903, or 1909, and report back, thanks.
ciao Beppe
Idonee
Hey. Thanks, did it today, checked on a project that crashed - the result has not changed. In other words, the same octane crash.
Idonee
Now crashes even when using the standard cinema gradient. Is there any chance of fixing this or telling me where to look for a solution?
mrom
I have the same problem, huge scene (for me, at least), constant crashes (c4d just gone), 2019.1.5 and 19.0.68, 442.50 as recommended, 980ti, 1070, 1080, 1080ti on a dual xeon workstation.
No c4d textures whatsover (even disabled), all 245 tex files in the tex folder. Had to switch to 2020, it's a bit better now (I wouldn't have done it in the final phase of a project, but I don't have a choice).
Oh, and please, just a question: if you enable texture compression at one texture, does it get cached in this folder?
C:\Users\USERNAME\AppData\Local\OctaneRender\cache\texCache\imageTex
Whenever I enable it at one texture, the compressed version never gets stored, my folder stays empty and everytime I resend the scene the materials get recompressed, very strange.
jerrymeer
Hi i got no solution but i want to report that also my C4D freezes when i use the Vanilla Gradient in the environment Tag. Its crashing only after reloading the scene in Octane.
