Volume within a volume bug.
Vassilis_Pi
Hello guys,
Does anyone knows if there a solution to this particular problem? Basically i have an octane fog volume in my scene and a second one which is a vdb.
As you can see in the picture i can see the edges of the vdb volume. Is there any fix?
It's hardly visible but this kind of problems are not unexpected. Try to use same "volume step length" for mediums of volumes.
Vassilis_Pi
Thanks for the reply!
Tried it and didn't had any luck unfortunately :(
I did some tries and used the same values here and there but it didn't go away.
These are not directly plugin related issues, but we can try to find a good parameter to fix it or pass to otoy developers if you post a sample scene as C4D or ORBX
Vassilis_Pi
aoktar wrote:These are not directly plugin related issues, but we can try to find a good parameter to fix it or pass to otoy developers if you post a sample scene as C4D or ORBX
Great, here is a sample scene. Thank you!
sample_scene.rar
(30.68 MiB) Downloaded 139 times
Try this parameter, you need to re-tweak the mediums. Because appearance will change after this.
Vassilis_Pi
aoktar wrote:Try this parameter, you need to re-tweak the mediums. Because appearance will change after this.
Worked like a charm dude, thank you so much for this!
