Hello guys,
Does anyone knows if there a solution to this particular problem? Basically i have an octane fog volume in my scene and a second one which is a vdb.
As you can see in the picture i can see the edges of the vdb volume. Is there any fix?
Volume within a volume bug.
It's hardly visible but this kind of problems are not unexpected. Try to use same "volume step length" for mediums of volumes.
- Vassilis_Pi
Thanks for the reply!
Tried it and didn't had any luck unfortunately
I did some tries and used the same values here and there but it didn't go away.
These are not directly plugin related issues, but we can try to find a good parameter to fix it or pass to otoy developers if you post a sample scene as C4D or ORBX
- Vassilis_Pi
Great, here is a sample scene. Thank you!aoktar wrote:These are not directly plugin related issues, but we can try to find a good parameter to fix it or pass to otoy developers if you post a sample scene as C4D or ORBX
- sample_scene.rar
- (30.68 MiB) Downloaded 139 times
- Vassilis_Pi
Worked like a charm dude, thank you so much for this!aoktar wrote:Try this parameter, you need to re-tweak the mediums. Because appearance will change after this.
