Cinema 4D version 2019.1.5-R3 (Obsolete stable) 12.02.2020
rclassenphoto wrote:if i open old scenes or render scenes the octane plugin crashes. i dont understand why?
i attached a Bug Report.
System is :
Octane 4.05 | Cinema 4D Studio R21.115
Win10 Prof. 64 bit
AMD Ryzen Threadripper 1950X 16-Core 4.00GHZ
Drivers: tried different from NVidia: studio 26.21.14.4166
3x 1080ti GTX Geforce
Bugreport doesn't give a detailed information. It show that's crashing at the renderer. Must attach a scene or send by Pm. Or activate log outputs and put c4doctanelog.txt
thanulee
Heya,
This version is fantastic. Testing it these days.
Noise doesnt seem to work inside a spotlight. I tried all projections. See image below. Is that a bug or spotlight cant accept noises in scattering? thanks
thanulee
Also by deleting the volume from light medium slot, still keeps a fog in my scene. Take a look:|
https://www.dropbox.com/s/rv25v9nw2rq1e ... e.c4d?dl=0
thanulee wrote:Heya,
Checked, there's a problem for internal connection of nodes. I'll try to fix it
thanulee
One more thing if possible. Do u think OSL sliders could limit in usable values?
eg. i play with noises and lacunarity goes from 0 to 232940 as i slide it and i when i reset to default, it goes to 0 instead of 2 for example.
Not something important, i just find it could be more convenient if every osl script could cap/limit within values that are used on that script.
Cheers!
thanulee
one last q: what is SDF object and how can we use it? :) thanks a lot Ahmet!
thanulee wrote:One more thing if possible. Do u think OSL sliders could limit in usable values?
Cheers!
some scripts have limited parameters, you can revise others if you take a look to format. I cannot fix every script in a short-term
thanulee wrote:one last q: what is SDF object and how can we use it? :) thanks a lot Ahmet!
It's something like this but seems not completed because doesn't accept material
rclassenphoto
System is :
Win10 Prof. 64 bit
I upload the "c4doctanelog" c4d crashes always happens with old files.
c4doctanelog.txt
(4.73 KiB) Downloaded 281 times
rclassenphoto
System is :
Win10 Prof. 64 bit
It just takes time and money!
Return to “Releases”
