Cinema 4D version 2019.1.5-R3 (Obsolete stable) 12.02.2020
DMAEuropa wrote:Will 2019 ever get RTX? i know we have 2020 XB but i see 2019 is still getting updates
It's a core feature and belong to 2020.x series. You get small and critical fixes from core and big updates from plugin side I'm adding to 2020.1 like multithreading for material creations
shine71 wrote:
aoktar wrote:
poison wrote:
Same with me Ahmet. wanted to try on my current project that features animated c4d noises (work in this release YES!!!) but i have lots of glass and transparency in general so that's a BIG NO NO. all comes pitch black.
materials are much much faster, absolutely lovely.
How soon can we expect that 2019.1.5-R2 ?
love.
Are you using the direct lighting kernel diffuse gi with fake shadow on the glass enabled? Also thanks!
Hi again Ahmet!
Yes, exactly.
We're using DL diffuse GI with fake shadow enabled.
Any tip?
Thanks a lot!
PS: new material conversion works like a charm!!!
Abstrax said that there was a bug in 2019.1.4 and fixed now
shine71
Thanks for replying, Ahmet.
But seems to be still not fixed.
I compared several simialr scenes and glasses are always darker, with light not apssing through in same way.
Unfortunately for this workflow we are forced to use DL... :(
I hope it can be fixed
PS: I'm attaching a quick example to show you what I mean.
shaddam
Posting a reply to compliment the test i did in the 2020 release ( viewtopic.php?f=85&t=73352&p=374861#p374861 (RTX shaved a whole minute off the render ! ))
Great speedup with the Multicore material conversion
Export materials time= 566.169 ms
Collect objects time= 0.245 ms
Mesh creation time = 40.443 ms.
VRAM used/free/max:2.545Gb/6.364Gb/11Gb  Out-of-core used:0Kb  RAM used:23.892Gb total:63.875Gb  OpenGL free/total:0/0
Multi-threaded material conversion, thread count=30
Export materials time= 49.224 ms
Collect objects time= 15.726 ms
Mesh creation time = 58.499 ms.
VRAM used/free/max:2.545Gb/6.364Gb/11Gb  Out-of-core used:0Kb  RAM used:24.268Gb total:63.875Gb  OpenGL free/total:0/0
Keep up the great work :)
J.C
Hello,
there is missing one mode in Render layer section. "Hide from camera" is not in the dropdown list.
edit:
previous releases has it missing as well.
System – Windows 11
stuz0r
For some reason this version is not showing up anywhere in Cinema 4D when I install it. I updated from 2019.1.3
My Nvidia driver is updated to the current studio version and all updates in C4D are up to date as well.
I have 2 GTX 1070 cards that I use.
stuz0r wrote:For some reason this version is not showing up anywhere in Cinema 4D when I install it. I updated from 2019.1.3
Wrong plugin location or version problem with c4d.
stuz0r
It's installed in the same location as the past several versions of Octane. Also, R21 is updated to latest version as well as the Studio drivers.
I went ahead and reverted back to 2019.1.3, installed it in the exact same place that I had 2019.1.5, and it is working again. :?:
stuz0r wrote:It's installed in the same location as the past several versions of Octane. Also, R21 is updated to latest version as well as the Studio drivers.
Tested latest build, it seems fine
rclassenphoto
if i open old scenes or render scenes the octane plugin crashes. i dont understand why?
i attached a Bug Report.
System is :
Octane 4.05 | Cinema 4D Studio R21.115
Win10 Prof. 64 bit
AMD Ryzen Threadripper 1950X 16-Core 4.00GHZ
Drivers: tried different from NVidia: studio 26.21.14.4166
3x 1080ti GTX Geforce
_BugReport.txt
(618.49 KiB) Downloaded 255 times
Return to “Releases”
