c4d hangs at startup ( R21 with every OC 2019 version)
useruser
hello,
meanwhile this is the third version of oc 2019 enterprise which causes a hang up at startup (plugin initializing)
this issue only appears with c4d R21. R20 with oc 2019 works without any problem ( same workstation)
deleting the "otoy_credentials" does not help.
the logfile shows nothing:
[2019-11-12 17:51:33][1] Register OctaneLive
thanks a lot in advance!
Workstation: Win 10 PRO 64 bit, 3,4 GHZ ,6-cores, 64 GB RAM , 4x RTX 2080 Ti
1. RenderSlave: Win 10 Pro 64 bit , 3x GTX 980Ti
2. RenderSlave: Win 10 Pro 64 bit 2x GTX 980 Ti
It may be due to blocking octane plugin from firewall or antrivirus software.
useruser
everthing is disabled. but the issue is still there
thanks in advance
1-be sure that everything installed correctly and using at least 21.022 not older version.
useruser
hi ahmet
nothing works. u updated everything ( C4d R21.026) disabled the firewall completely but octane hangs at startup
i also tried to add a specific firewall-rule for R21 (incomming and outcomming tasks) but nothing helps
i also deleted every other plugin
i installed the oc-standalone and the slave-daemon, both are working on the workstation without any trouble.
C4d R20 works also without any problem
thanks in advance! :)
What's install path for plugin?
useruser
C:\Program Files\MAXON\Cinema 4D R20\plugins\c4doctane
Why do you show R20 version? You say R21 is not working..
useruser
sorry
that was the wrong screenshot
this is the right one:
the oc-plugin is installed in the first directory. but no matter which one i use: the result is all the same.
hangs on startup
Please, change the name of the folder from Plugins to plugins, and install only a copy of c4doctane folder, removing in it the unnecessary .cdl64/.xdl64 files not related to R21.
ciao Beppe
