Crashing : almost always related to materials
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
HTK421
Octane Crashes a LOT (like 2 - 3 time per hour) and most of the time it happens when I make 'any' changes to materials.
This scene file is small (see attached bug report and scene file)
It's a new scene, containing only 1 plane object.
I added a new diffuse material, and it crashed in the same way that it does every other time that I add or adjust materials while the live viewer is running.
A cannot send an octane log because it crashes before it writes anything
SYSTEM SPEC
CUDA driver: STUDIO 431.86
Render plugin V 4.05 R6
WIn 10 v1809
32Gb Ram
Intel i9 10-core
Evga Nvidia 1080Ti x 3
OCTANE CRASH FILE.7z
bur report and scene file zipped
(57.97 KiB) Downloaded 249 times
Can you send a c4doctanelog.txt with all log outputs activated as soon as crashed.
HTK421
Ahmet, please tell me where to find that log file. What is full windows path?
Loading the scene that gives "not enough memory" error.
HTK421
I dont always get the "not enough memory" error upon crash.
When a crash happens the whole of C4D locks up.
I have to go 'Task Manager' > 'End Process' to kill it, and then restart C4D.
When I reload that project the Octane log has NO information other that when it started (see attached).
Please note: If I send the "Maxon bugreport" to Maxon, they write back and tell me the crash was caused by the Octane plugin.
log pic.jpg (9.37 KiB) Viewed 6850 times
HTK421
Octane Log attached
Another crash related to materials.
Since my original post, I have upgraded Windows to 1903
and removed Intel TurboBoost app that was 'possibly' causing CPU issues,
and unchecked the GPU Priority boxes in settings.
I get fewer crashes now (but still far too many) , but as I originally stated, the crashes that I do get are still mostly when editing materials
Please see log file
regards
Toby
c4doctanelog.txt
Octane log file
(3.62 KiB) Downloaded 241 times
HTK421
HOT TIPS to reduce Octane crashing
After weeks of relentless crashing (like several times an hour) I raised a ticket with OTOY help team. Bepe (great guy) got me to do several system checks & diagnostics, and discovered a list of things to tune.
The changes we made have reduced the crashing dramatically so here they are. I hope this helps anyone who is also suffering a lot of crashes.
  1. Make sure your windows OS is up to date (I upgraded from 1809 to 1903). You will need to do this in order to run the latest drivers.
    Only use Nvidia 'Studio' drivers, not Gaming or Beta drivers. Nvidia make you choose which type when downloading from their site, so in the Manual Driver Search panel, click the 'All' menu - here you will find Studio as an option.
    Disable 'OpenGL' in Octane. This on by default (and probably shouldn’t be!). It is done in two places:-
    • Octane Settings > Other (tab) >'Use Octane for Opengl previews' (uncheck this).
      Octane Dialog > Options (menu) > 'Opengl previews' (uncheck this).
    Make sure your Devices (GPU) priority is set properly. In 'Octane Settings' go to 'Settings' (tab) > Devices (tab).
    • Set Priority to LOW
      Make sure all your GPU cards are checked in the first column
      In the Priority column, only check the GPU that is running your monitor(s). Leave the others unchecked.
    Make sure that your GPU cards are not overclocked. Check your part number as some come pre-overclocked.
    Disable any CPU booster application (eg Intel Turbo Boost).
Disabling the opengl previews is not a good idea. And it should work fine without doing this. It will broke some functionality.
boxoffrogs
Just a quick finding for anyone who has texture-related crashes. What worked for me is disabling "Multi-Thread for materials" in Settings > Other.
Return to “Bug Reports”
