Cinema 4D version 2019.1.2-R4 (Stable) 25.10.2019
freakanay
Hey!
I think i found a small bug, shadowcatcher always worked fine in combination with a gradient, however when i do that now, the whole shadowcatcher breaks. See example
edit
edit
Seun116_1
Found an issue. It seems like the film layer doesn't work when you have the "Metallic reflection Mode" set to Rgb IOR. I've tried the same scene with with the latest 2018/2019 version and film layer only works on 2018. Also it seems like metallic materials are processed differently. This metallic object in latest 2018 looks drastically different from the gold in latest 2019. Same scene and everything, only thing I switched out was the plugin.
metallic test.zip
(75.66 KiB) Downloaded 311 times
Latest 2019
Latest 2019
Latest 2018
Latest 2018
tomsvfx
What are R3 and R4 changes?
Kalua
tomsvfx wrote:What are R3 and R4 changes?
Review the first post, Tomsvfx.
C4D 2025.1.1 Octane v1.9 // Octane SA 2026.2, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, NVIDIA SD 595.79
Octane User since V1 Beta
tomsvfx
Thanks, wasnt there when I asked.
silkyre6xtenz
Well, there is nothing in the first post. There are only info on 2019.1.1-R4 and 2019.1.2-R2
There is nothing else
BCres
2019_1_2_R4 is available. It has been for several days. I downloaded it on the 25th.
Mouseover the link to download your edition and read the file name.
Here's a screenshot I just took. Look at the file name at the bottom of the page.
philip.gedarovich
Thank you Aoktar for all of your great work!
When do you think RTX raytracing support will be integrated? Will it be released for C4D Octane 2019 this year?
philip.gedarovich wrote:Thank you Aoktar for all of your great work!
I have a working prototype but I'm holding that because material preview crashes on displacement nodes. I'll make release soon after next fixed sdk
smessing
Hey Aoktar -
This is wonderful. Thank you for all the hard work.
I was wondering if there is a pixel aspect ratio option that is going to be added to the universal camera. Currently when I change the aperture aspect ratio it scales the result as it would physically look - the old thin lens had this pixel aspect option in the viewing angle section. Is this going to be added or am I missing some other way of achieving this?
Thanks again
-Steven
Return to “Releases”
