Cinema 4D version 2019.1.2-R4 (Stable) 25.10.2019
Hi all,
This is new build with a stable version of 2019.1.2 SDK.
Any feedbacks are welcome for development and fixing the issues. Enjoy it!
This is the matching SDK for the 2019.1.2.
See all new features of 2018/2019 versions.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also, make sure you use a driver of version 419.xx or higher and if you are working on Mac OS that has a CUDA driver installed that supports at least CUDA 9.1.
1- Prefer NVIDIA STUDIO drivers. If you have stability issues try different drivers, some of them could cause instability issues. Do a clean install while doing this to be sure previous files completely removed.
Changes of 2019.1.2-R2
- Added pick-focus support for Universal camera
- Invert option for VertexMap texture
- Minor fixes
Changes of 2019.1.2
- Universal camera and re-factored camera tag interface
- Minor fixes
Standalone(core) fixes
  • Fixed toon material rendering incorrectly for camera toon light.
  • Fixed toon material causing a render failure in the material preview.
  • Fixed multi-layered material not outputting multi-layered bump mapped / mapped normals in info passes
  • Fixed volume render inconsistency when using legacy mode.
  • Fixed incorrect denoiser output when enablign some light passes.
  • Fixed upsampler not working properly for the very first time on some GPUs (this does not fix the upsampler on Win 7, which is still an unsolved problem).
  • Fixed kernel crash when using accurate rounded edges if adjacent geometry of an edge is a displacement triangle.
  • Fixed discontinuities in shading normals for some cases when using fast rounded edges.
  • Fixed a bug in the vertex normal calculation of vertex displacement geometry which was causing the geometry to look facetted when using the join unwelded vertices option.
  • Fixed net render slave crash when a scene contains images compressed on the master.
  • Updated the universal camera:
    • All camera modes now conform to a unique set of pins.
    • Added equirectangular and cubemap cameras.
    • Added aberration, coma, field curvature, astigmatism and spherical aberration to the thin lens camera.
    • Added keep-upright to all cameras.
    • Added clipping and pixel aspect ratio to fisheye and panoramic cameras.
    • Added lens shift to panoramic cameras.
    • Fixed autofocus and focus picking.
    • Fixed bokeh in fisheye camera for polygonal apertures.
Changes of 2019.1.1-R4
- Fix for a possible crash after specific steps: Render/Pause/Close_LV/select any Octane stuff
- Fix: "Aperture edge" parameter for universal camera
- Fix: dynamic pins for displacement mixer node
Changes of 2019.1.1-R3
- Keeping node attributes in localdb materials.
- Fix: Hang issue in quit phase after some specific operation
- Fix of some missing livedb material convert functionalites
- Small fixes for nodes
Changes of 2019.1.1-R2
- Missing transmission type in universal material
- Fix: (De)select all passes button
- Added: Motionblur support on splines with ObjectTag->Hair render
- Fix: update issue for R21 material previews due to changes of R21 SDK
WINDOWS ENTERPRISE BUILD (R15-R21)
https://render.otoy.com/customerdownloa ... R4-win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-R21)
OSX ENTERPRISE BUILD (R15-R21)
https://render.otoy.com/customerdownloa ... Macosx.zip
OSX SUBSCRIPTION(Studio) BUILD (R15-R21)
R15-res.rar
(15.35 MiB) Downloaded 376 times
WINDOWS DEMO-BUILD (R15-R21)
https://render.otoy.com/plugindownloads ... R3-win.rar
OSX DEMO-BUILD (R15-R21)
https://render.otoy.com/plugindownloads ... Macosx.zip
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.022). Otherwise, the plugin will not work and not appear in menus.
-Updated Nvidia drivers at least Nvidia Studio Drivers(419.x/431.xx) and be careful with latest Game Ready drivers which can cause cuda errors. Avoids to use 418.81.
-Cuda 9.1 driver for OSX.
ONLINE HELP MANUAL
To use OFFLINE version of manual from plugin
Download following package and extract to Cinema4D/plugins/c4doctane/manual
https://render.otoy.com/plugindownloads ... p-html.zip
V3 SAMPLE SCENES SET(make a request if you need any specific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Cinema 4D Release 20: c4dOctane-r20.xdl64 or c4doctane_R20_demo.xlib
Cinema 4D Release 21: c4dOctane-r21.xdl64 or c4doctane_R21_demo.xlib
Kalua
Great stuff, Aoktar. Thank you!
Does the focus picker work with the Universal Camera?
Cheer!
C4D 2025.3.3 Octane v1.9.4 // Octane SA 2026.4, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
Kalua wrote:Great stuff, Aoktar. Thank you!
Cheer!
If it's not working that's due to different logic of universal camera interface. It needs to be fixed
thanulee
Thanks a lot Ahmet, u rock!
rezaansari
Thanks Ahmet
I have a question.
need to have an All-Access license to use this version?
I mean versions 2019
divasoft
Focus peaking and focal depth parameter not works with universal camera.
And aperture texture not implemented yet? Why? We are all waiting for this. corona, redshift, vray - all have long acquired this.
divasoft wrote:Focus peaking and focal depth parameter not works with universal camera.
Answered that above.
A positive attitude is always better. Also I'm not right people to be asked for a missing core feature. Try standalone forums.
divasoft
Thanks for you answers.
You said above that: "If it's not working that's due to different logic of universal camera interface. It needs to be fixed", but by whom and when should this be fixed?
Without focus picking it is impossible to use the universal camera at all.
I've released that one day ago and fixed one day later in weekend. I'll release it in hours.
divasoft
aoktar wrote:I've released that one day ago and fixed one day later in weekend. I'll release it in hours.
Wow, good news, thanks for your work)
