Cinema 4D version 2018.1.3-R5 (Latest stable) - 07.10.2019
Kalua
Aoktar:
Another smal thing that has been going on with 2018.3-R2 and 4.05-R3: the render region is now offseting in relation to the red marquee drawn by the user. Is a random behavior, starts working fine until something makes it offset Take a look at the .gif.
Cheers
Octane User since V1 Beta
Kalua
Hi, Aoktar.
These are other two things I noticed:
1.Why are the Anysotropic and Film index lacking the nodes entry?
2.Blend Shader: there erros with the input values for mixing each material, looks like the plugin is multiplying the values I write .
2.Blend Shader: there erros with the input values for mixing each material, looks like he is multiplying the values I write .
Kalua wrote:Hi, Aoktar.
1. They are just float values without having texture inputs.
2. It's a gui problem, I've fixed for next builds.
mesut
Kalua wrote:Aoktar:
Cheers
i experience the same in r20 and with the latest 4.05 plug.
that's a first for me.
win7prof. | i7 4930, 32gb | 2*980ti 6g for renderings | 1*660 for displays
Packages updated with addition of R21-OSX builds. Preview ball update issue is not fixed yet. Enjoy it!
Seun116_1
Image Texture materials/colors are loading up correctly in the C4D viewport! Thanks for the fix!
Seun
MyDearestHao
I also encountered it before, and the rendering is not possible. How can I solve this situation?He told me to open the wrong report, where can I see this?
http://www.aoktar.com/octane/Troubleshooting.html
and be sure not having out of VRAM/RAM
MyDearestHao
aoktar wrote:
MyDearestHao wrote:
The attachment 渲染失败.png is no longer available
= = 。 I opened it and copied it directly to Notepad. See if this can be done.
log.rar
(6.13 KiB) Downloaded 270 times
AaronWestwood
Using the updated R3, inside R21, Scatter seeds still behave incorrectly/broken. Any ideas when this will be addressed (only asking as I need it for a current job :) )
To be clear these are the issues, that never existed prior.
- re positioning the source geometry re seeds
- scaling the clone re seeds
- rendering to picture viewer re seeds
- undoing a seed change re seeds
This can be replicated using a simple plane + scattering spheres. Nothing fancy.
3D Environment Artist
http://www.artstation.com/aaronwestwood
2 x 4090 // 13900KS // 96GB 5600mHz DDR5 // Windows 11
Return to “Releases”
