Hi All,
This is a hotfix release of the Cinema 4D 2018.1.3 plugin which is based on 2018.1.3 SDK and matches OctaneRender Standalone 2018.1.3.
For OSX users with stability issues, please use "Synchronization on geometry updates=OFF" from Settings/Other section.
New features
To learn more about the new features and improvements of OctaneRender 2018.1, please check out the 2018.1 release post, but this a quick list of the main new features that have been added:
What's new in 2018
Cryptomatte
Deep render passes
Vectron (analytic geometry)
Vertex Attributes
Spectron (procedural volumetric light system)
Much less volume render noise
NV Link support on RTX 2080 and RTX 2080 Ti (Enterprise only)
Direct Levelset surface rendering from VDB (can be fed into Vectron)
Scatter depth limiting (i.e. fast fog rendering)
Cached compressed textures
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also, make sure you use a driver of version 387 or higher and if you are working on Mac OS that has a CUDA driver installed that supports at least CUDA 9.1.
1- Try different drivers, some of them could cause instability issues. Do a clean install while doing this to be sure previous files completely removed.
Changes of 2018.1.3-R5
- Missing transmission type in universal material
- Fix: (De)select all passes button
- Added: Motionblur support on splines with ObjectTag->Hair render
- Fix: update issue for R21 material previews due to changes of R21 SDK
Changes of 2018.1.3-R3
- A few minor fixes for issues of previous build
Changes of 2018.1.3
- Ability to change the custom lut directory
- Fix: Delay problem on ImageTexture while you have lot of files in search paths
- Fix: OOC-RAM is set according to the system ram
Changes of 2018.1.2-R2
- Octane device settings button added
- Fix: missing seen/coating bump/normal textures
- Fix: resetting the old path problems with ImageTexture
- LOD object support
- External script mode for vectron/osl_texture nodes.
- Minor changes
Changes of 2018.1.2
- Fix: Stealing the slaves and better operating with "Bind all"
- Fix: Possible wrong assignments with gpu devices
- Fix: Node editor: Node preview flickers and performance drop by unnecessary material updates
- Fix: Crashes with material previews.
Changes of 2018.1.1-R2
- Fix: R20.059 stability issues.
Changes of 2018.1.1
- Added Deep image rendering
- Fixes for osx build
- Fix: Performance problem due to wrong texture caching of image textures
- Performance improvements for scene editing
- Fix: LV resizing problems
Changes of 2018.1-R3
- Fix: Reloading issues in ImageTexture
- Fix: Filename conflict with absolute path against relatives, when we have same files in texture search paths
- Addon: Custom LUT combobox in Camera Imagers and settings
- Fix: Connection problem into color pins of osl scripts with some internal octane types(rgb,float,gaussian,...)
- Added ability to break rendering in Picture Viewer at material creation phase
Changes of 2018.1-R2
- Fix: inoperative color/texture parameters of osl scripts in Osl Camera.
- Fix: Uninitialized sheen parameter
- Fix: Mix to Blend material conversion
- Fix: Missing parameters in cryptomatte settings
Changes of 2018.1
- Added: Spectron(Volumetric spot light)
- Fix: ImageTexture and Texture Manager linking problem
- Missing new coating and sheen parameters added
- Fix for InstanceColor id interactivity problems with render instance and multi-instances
- Extended 3rd party support with connection functions
- Fix: Possible memory leak on usage of "Use denoised beauty pass" parameter.
- Fix: Node previews work without having render session.
- Fix: Wrong IDs for light linking invert
WINDOWS ENTERPRISE BUILD (R15-R21)
https://render.otoy.com/customerdownloa ... R5_win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-R21)
OSX ENTERPRISE BUILD (R15-R21)
https://render.otoy.com/customerdownloa ... Macosx.zip
OSX SUBSCRIPTION(Studio) BUILD (R15-R21)
WINDOWS DEMO BUILD (R15-R21)
https://render.otoy.com/plugindownloads ... R5_win.rar
OSX DEMO BUILD (R15-R21)
https://render.otoy.com/plugindownloads ... Macosx.zip
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057). Otherwise, the plugin will not work and not appear in menus.
-Updated Nvidia drivers at least 388.xx, recommended 417.22 or 419.17 (one of most recent with Cuda 9.1) and be carreful with latest drivers which can cause cuda errors. Avoids to use 418.81.
-Cuda 9.1 driver for OSX.
ONLINE HELP MANUAL
To use OFFLINE version of manual from plugin
Download following package and extract to Cinema4D/plugins/c4doctane/manual
https://render.otoy.com/plugindownloads ... p-html.zip
V3 SAMPLE SCENES SET(make a request if you need any specific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Cinema 4D Release 20: c4dOctane-r20.xdl64 or c4doctane_R20_demo.xlib
ORBX EXAMPLE VIDEO
https://vimeo.com/302046063
Node sliders
https://vimeo.com/268974364
Viewport rendering mode
https://vimeo.com/265747658
https://vimeo.com/265294205
Cinema 4D version 2018.1.3-R5 (Latest stable) - 07.10.2019
- aymenchemli
hi guys help please i have the version 4.04 r2 and i want the v 2018 i my c4d dont want load even when i install it ??
You need an update on licenses for 2018/2019 over V4.aymenchemli wrote:hi guys help please i have the version 4.04 r2 and i want the v 2018 i my c4d dont want load even when i install it ??
Thank you, Aoktar
Feels very stable overall!
Question: what's the benefit of the "Octane device settings button" ?
C4D 2025.3.3 Octane v1.9.4 // Octane SA 2026.4, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
It's for changing the settings which are not visible in plugin side. For example NVLINK. Thanks!Kalua wrote:Thank you, Aoktar
Glad to hear, enjoy it!thanulee wrote:Thanks Ahmet!
- Augustronic
- Contact:
Hello aoktar,
I have scene, setup with the non-enterprise version of Octane.
It contains an animated texture sequence.
This texture is not rendered on the clients with the enterprise version of Octane on the render farm.
Have a nice day!
Achim
Have a nice day!
Achim
Have a nice day!
Achim
Aixsponza
Achim
Aixsponza
There's not any different about texture features that I can know. There may be a different problem. Try to investigate by running the plugin and render.Augustronic wrote:Hello aoktar,
Have a nice day!
Achim
Okay, so I installed 2018.1.3 today on the main machine and on my second render box. And installed the plugin for Cinema 4d.
I signed in on the main machine, and signed in on the slave demon through the run_installed_daemon. This is the way I have done this forever.
I also have an Enterprise AA subscription and suddenly I ma seeing these errors roll by on the Octane_slave Command window. I've attached a picture.
Why is this happening?
Could this be the reason?
It looks like it may be getting confused on which license I am using. How do I delete that second license. I had to do it this way with the old version where you were forced to buy a full license just to render on the second box.
