This build has been updated to the 2019.1.0.2 release to fix a critical performance issue in the scene extraction that was affecting some of the Windows builds.
OctaneRender 2019.1 LightWave beta build 2019.1.0.2 RC3
- BorisGoreta
- Contact:
Material mixer is not working properly, 0% and 100% on material mixer is not the same as overriding the mixer with 2 material inputs.
- electric_eric
- Contact:
Anyone else getting issues with Octane lights in open gl?
If I set a light to Octane light then the open GL display goes into cel shade mode, as if the octane light is a toon light.
Intel i7 6700k - 64gb Ram - 6 x 980ti
- BorisGoreta
- Contact:
Yes, you need do disable OpenGL for that light.
Hi,BorisGoreta wrote:Material mixer is not working properly, 0% and 100% on material mixer is not the same as overriding the mixer with 2 material inputs.
There is a fix in the 2019.1 RC5 that perhaps is related to your issue. You could check in Standalone if it is fixed while we release a new LightWave plugin build including this core.
Fixed mix material not consistent with rendering specular layer + diffuse material when swapping input pins.
Sorry, what is exactly the problem that you have with this feature? There is a known issue related to the image distortion at some resolutions ... not sure if you are experiencing this same issue.promity wrote:What about AI upsample? looks broken for me.
- Rainbow-3D
juanjgon wrote:Sorry, what is exactly the problem that you have with this feature? There is a known issue related to the image distortion at some resolutions ... not sure if you are experiencing this same issue.promity wrote:What about AI upsample? looks broken for me.
To me upscaling (NO AI) works. If I enable AI upscaling option, it crash the system (computer reset).
Ty
Gianluca
Win 7 x64 | Asus P8P67-M - i72600K | 16 GB RAM | 1 x nVidia RTX 2800
Win 11 | i7 13700K | 64 GB RAM | 1 x nVidia RTX 4090
