Cinema 4D version 2019.1-RC3_r2 (Test build) - 16.08.2019
Hi Ahmet. I have a question. Why texture baking node in Cinema works so slow and freezing Cinema for 10... 30... and more 60 seconds every time when i do something? Even simple opening node editor with bakingnode may freezing Cinema for minutes? In standalone texture baking much faster - 1-3 seconds with no freezing for my any action.
Freezing means that's recalculating baked texture. Have you see that on every case or on specific one? I'm away for a while, hard to help atmdivasoft wrote:Hi Ahmet. I have a question. Why texture baking node in Cinema works so slow and freezing Cinema for 10... 30... and more 60 seconds every time when i do something? Even simple opening node editor with bakingnode may freezing Cinema for minutes? In standalone texture baking much faster - 1-3 seconds with no freezing for my any action.
Octan node editor not showing previews. It will show, it will not show. Very unstable. Why is there no preview of the color correction node and other nodes? We have to change the parameters at random. Changing the hue parameter by one out of five times leads to a cinema crash.
https://drive.google.com/open?id=1qtplF ... 08cJhCO33W
- eyeonestudio
- Contact:
Thank you for your effort. ...
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
It happen only when LV is not open. I'll take a lookdivasoft wrote:Octan node editor not showing previews. It will show, it will not show. Very unstable. Why is there no preview of the color correction node and other nodes? We have to change the parameters at random. Changing the hue parameter by one out of five times leads to a cinema crash.
Edited...
Have no alpha using Affect Alpha in SpecMat. Rendered with Render Layer (Upd.: the same result w/o RL).
Please, see pic
upd.: Have found only way to get alpha in SpecMat is to turn completely Off reflection chanel. Even if the mat has a small amount of reflectivity, there will be no alpha in SpecMat.
Thank you
Please, see pic
Thank you
The Toon Shader is crashing, with the typical "Check the Log"...
- octane 2019.1 RC2 190808 173907.log
- (4.48 KiB) Downloaded 270 times
Updated the plugin with new SDK(2019.1-RC3)
- eyeonestudio
- Contact:
It's built with R21.015, so you may need this version or later.eyeonestudio wrote:Not Working with R21 latest version....
WARNING: Error loading
file:///C:/Program Files/Cinema 4D R21/plugins/c4doctane/c4dOctane-R21.xdl64:
symbol 'g_maxon' is missing. [win_dll.cpp(393)] [general.cpp(386)]
