Cinema 4D version 2019.1-RC3_r2 (Test build) - 16.08.2019
Hi all,
This is new build with Release Candidate version of 2019.1 SDK. We still consider this an experimental build, until we leave the RC status. Please don't use this for production purposes.
Any feedbacks are welcome for development and fixing the issues. Enjoy it!
This is the matching SDK for the 2019.1 RC2Standalone.
See all new features of 2018/2019 versions.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also, make sure you use a driver of version 387 or higher and if you are working on Mac OS that has a CUDA driver installed that supports at least CUDA 9.1.
1- Try different drivers, some of them could cause instability issues. Do a clean install while doing this to be sure previous files completely removed.
Changes of 4.05-R2
- Fix: Ignored "normalize" parameter of Octane Light tag
- Fix: Performance issue on Volume object when use empty filename
- Improved material/tag/object import/update on Node Editor
- Fixed some problems on R21 for Node Editor
Changes of 2019.1-RC3
- Fix: max value=254 for render_layer_mask pixels with PNG
- Added OslBaking Camera
- Improved Node Editor support for Octane objects and Octane tags
- Small change on InstanceColor
Important warning: Do not post any screen shots from R21 until it releases officially.
WINDOWS ENTERPRISE BUILD (R15-R20)
https://render.otoy.com/customerdownloa ... r2_win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-R20)
OSX ENTERPRISE BUILD (R15-R20)
https://render.otoy.com/customerdownloa ... Macosx.zip
OSX SUBSCRIPTION(Studio) BUILD (R15-R20)
RES file for R15
https://render.otoy.com/customerdownloa ... 15-res.rar
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.016). Otherwise, the plugin will not work and not appear in menus.
-Updated Nvidia drivers at least 419.x and be careful with latest drivers which can cause cuda errors. Avoids to use 418.81.
-Cuda 9.1 driver for OSX.
ONLINE HELP MANUAL
To use OFFLINE version of manual from plugin
Download following package and extract to Cinema4D/plugins/c4doctane/manual
https://render.otoy.com/plugindownloads ... p-html.zip
V3 SAMPLE SCENES SET(make a request if you need any specific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Cinema 4D Release 20: c4dOctane-r20.xdl64 or c4doctane_R20_demo.xlib
Cinema 4D Release 21: c4dOctane-r21.xdl64 or c4doctane_R21_demo.xlib
eyeonestudio
Last edited by eyeonestudio on Thu Aug 15, 2019 12:18 am, edited 2 times in total.
spliffiam_1 wrote:IS RTX ON?!?!?!
Nvlink yes, rtx core no!
spliffiam_1 wrote:Ah rip, i have another problem tho.
This is from 2018.3 https://i.gyazo.com/thumb/1200/5760db99 ... 4d-jpg.jpg
and this is same scene from 2019.1 https://gyazo.com/b8c0114433752a6b18bad0b52c5e35fb
As you can see the colors and the volume is very different, color thing might just be from the volume being weird i guess but any idea why this is happening?
Don't know! Please make some tests to understand what's happening. Or share a scene
Kalua
Hi, Aoktar
In r18 the plugin keeps saying is RC1. Is this just a spell error?
Cheers!
C4D 2025.1.1 Octane v1.9.3 // Octane SA 2026.3, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
Kalua wrote:Hi, Aoktar
Cheers!
Yes appearently it's my mistake. But it's RC2, you can be sure by checking CONSOLE output. You should see following line
Loaded Octane DLL:OctaneRender Enterprise 2019.1 RC2 version:6000003 SDK:2019.1 RC2
Kalua
Cheers!
Thank you, Aoktar
One more question: where do I find the "thin wall" for specular shaders?
adamwhatelse
Hi Guys,
I am probably just blind, but can someone tell me where i could find some documentation on the new features, and how to implement them?
I am especially curious about the "AI Up-sampler".
The help file is from Version 4 and even an online search didn't bring up anything, which i find strange..
thx in advance!
jayroth
Hi Ahmet,
Is displacement mixer limited to vertex displacement only?
CaseLabs Mercury S8 / ASUS Z10PE-D8 WS / Crucial 64GB 2133 DDR4 / 2 XEON E5-2687W v3 3.1 GHz / EVGA 1600 P2 / 2 EVGA RTX 2080Ti FTW3 Hybrid/ Cinema 4D
Is it fast? Oh, yeah!
NC17z
Has anyone had trouble with Live DB Materials and Textures? I can't seem to get any of them to work on an object in C4D. They just look like the default white.
