see image:
It's a pair of days Octane IPR does not show any info - samples, timing etc. Even when i load a scene it just says "loading" but does not show which object is loading.
While rendering i can't see samples or anything, just "loading" as in attachment, and when it's done it says "done", nothing else.
I cannot even See Region borders. It works, since it render just the area i select, but no border is visible.
The only option i found about IPR info seems already active (see arrow).
Any idea ?
thanks
Paolo
							IPR does not show infos
Sorry, I'd never seen anything like that. Do you have this problem with all the scenes or is it related to that one only? I wonder if there is a problem with the drivers or something like that. Perhaps you could try to delete the "LWOctane.cfg" file from your configs folder to clean the Octane plugin configuration, but I can't figure how something like that could happen due to a broken configuration.
