volumetric medium texturing not working
Forums: volumetric medium texturing not working
Postby Pavlov » Fri Jul 19, 2019 12:54 pm
Pavlov Fri Jul 19, 2019 12:54 pm
hello,
in this scene i've a big box wiht transmissive material and a medium node plugged in, and i get a nice volume fog effect.
Now i'd like to have it a density variation in volume so i plug a map in Medium but nothing happens.
To keep it simple i tried a check texture, which is B/W so effect should be strongly noticeable. If i apply the map to Volume Box's material we see it's correctly sized and placed:
so i would expect a visible effect on volumetrics but nothing happens, no matter where i plug the node.
Is there a way to texturize density/scattering ?
thanks
Paolo
I7 960 3.2 GHZ - 6GB ram - GTS 250 display only - Asus GTX 470
Pavlov
Re: volumetric medium texturing not working
Postby AndyM1969 » Sat Jul 20, 2019 9:55 am
AndyM1969 Sat Jul 20, 2019 9:55 am
Are you plugging the volume into the object surface material?
AndyM1969
Postby Pavlov » Sun Jul 21, 2019 4:59 pm
Pavlov Sun Jul 21, 2019 4:59 pm
Yes, unsing a 100% transmissive material and plugging a medium there will give you a "fog box" like the one you see.
Better than medium into Rendertarget since you can control it's position and distance to camera - i.e. in this case i need fog to start at a given distance from camera and you cannot get this effect with Render target Medium.
Problem is it seems you cannot set local density/scatter, if you plug any map there it sill not obey to the map.
Paolo
Pavlov
Postby dsol21 » Mon Jul 22, 2019 2:57 pm
dsol21 Mon Jul 22, 2019 2:57 pm
Are you using the actual Octane volumetric object to create this textured fog? As in - adding an Octane Fog Volume object - under the Custom Objects in item properties. If you do, then a texture node is available (that takes in standard Lightwave procedural textures) for the density
dsol21
Postby Pavlov » Mon Jul 22, 2019 9:22 pm
Pavlov Mon Jul 22, 2019 9:22 pm
no i'm using a box with a simple transparent material and a medium plugged into material.
I saw the volumetric object, i'll give it a try, thanks !
Paolo
Pavlov
Postby AndyM1969 » Tue Jul 23, 2019 1:50 pm
AndyM1969 Tue Jul 23, 2019 1:50 pm
Yeah, use the volume object, make sure you triangulate the polygons in modeller, and you can plug Lightwave native procedurals for your texture.
AndyM1969
Return to Lightwave 3D
Sat May 30, 2020 4:02 pm [ UTC ]
