Arbitrary range
spigolo
I noticed that Octane on lightwave doesn't support the arbitrary range in the render properties.
I need to render only certain frames of a setup but and I wrote the frames to be rendered like 2-3-7 etc...
but after the first 2 it stops rendering.
Also in the past I noticed that it didn't worked ..is this a known limitation?
3dsign studio
Advanced visual communication
http://www.3dsign.it
juanjgon
This sounds like a bug. I'll check it.
spigolo
What I can tell you for sure is that if you assign an arbitrary range like 3,5,7,11 after the last frame Octane restarts rendering
from the first frame...
3dsign studio
spigolo
Hello Juanjo
have you cheked this bug?
It is very annoyng also as Octane restarts rendering and the only way to stop it is killing the process...
thx
3dsign studio
juanjgon
Sorry for the late reply. I'm trying to find and fix this issue for the next build right now ...
spigolo
3dsign studio
juanjgon
Ok. This problem seems related to a bug in LightWave. The LW team is aware of it, so I hope they could find a solution for the next LW build(s), but meanwhile, I've added a workaround in the plugin code that hopefully could fix this problem. I'll include this fix in the plugin builds.
pixym
Thanks Juanjo.
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10
Net render : MB Asus Pro WS W790E-SAGE SE - XEON - 128GB - 2 x RTX 3090 - 3 x RTX 2080TI
Lewis
In LW 2015 and Octane 4.04 that works fine so it's either LW 2018----> bug or octane 2018.x bug ?
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
juanjgon
To me, this is a bug introduced in LightWave 2018
Return to “Lightwave 3D”
