Problem with RGB image textures
You might have the gamma set incorrectly on the texture.
- fabrizio_s
Has the material some reflections? I mean...maybe Visible Environment affects the color...
Can you provide the .3dm file for this pls so I can test it?Gamma is set to 2.2, so I guess it's correct
It's just diffuse material with only diffuse map, environment is whitefabrizio_s wrote:Has the material some reflections? I mean...maybe Visible Environment affects the color...
Sure, thanks!face_off wrote:Can you provide the .3dm file for this pls so I can test it?
- test_scene.zip
- (3.92 MiB) Downloaded 361 times
It looks pretty close to me. You didn't provide the background bitmap (checkers), so I just rendered with RGB Texture 255/255/255 in the environment.
If the Octane plugin is rendering the diffuse texture in the same way that Rhino does, then it seems it is working OK. If they were different, there would be a problem.You compared render with Rhino viewport if I'm correct and it's the same at my computer. The difference was between Rhino/Octane and jpg viewed on Windows image browser and other applications.
