Problem with RGB image textures
lemonade
I noticed that diffuse color in my render is somehow different than my texture - is it something I can fix?
You might have the gamma set incorrectly on the texture.
lemonade
Thanks for your answer ;)
Gamma is set to 2.2, so I guess it's correct
fabrizio_s
Has the material some reflections? I mean...maybe Visible Environment affects the color...
Can you provide the .3dm file for this pls so I can test it?
lemonade
fabrizio_s wrote:Has the material some reflections? I mean...maybe Visible Environment affects the color...
It's just diffuse material with only diffuse map, environment is white
face_off wrote:Can you provide the .3dm file for this pls so I can test it?
Sure, thanks!
test_scene.zip
(3.92 MiB) Downloaded 291 times
It looks pretty close to me. You didn't provide the background bitmap (checkers), so I just rendered with RGB Texture 255/255/255 in the environment.
lemonade
You compared render with Rhino viewport if I'm correct and it's the same at my computer. The difference was between Rhino/Octane and jpg viewed on Windows image browser and other applications.
If the Octane plugin is rendering the diffuse texture in the same way that Rhino does, then it seems it is working OK. If they were different, there would be a problem.
lemonade
Ok, thank you.
So there's no way to fix how Rhino changes the colours compared to other apps?
Return to “Rhinoceros 3D”
