Displacement and Scatter
Sub forum for feature requests etc
Kretschi
Hello,
It would be nice if the Octane Scatter took the displacement node into account.
Now it is nearly impossible to scatter something on a displaced object. (e.g. some stones or vegetation on a displaced terrain..)
Is this possible to do in the future?
Would be great.
Hi Kretschi,
have you tried with a c4d displace deformer, instead of material displacement?
ciao beppe
Kretschi
Hi Beppe,
Yes, I know... but with a resolution of 4096x4096 I would get a mesh with nearly 17.000.000 polygons.
Cheers, Andreas.
You can do it easily. Have you checked position parameter in scatter object?
Kretschi
I put the same texture from the displacer in the shader channel of the Scatter position....
mid level of the displacer has to be 0
this works, great!
(I only don't get the right normal direction...)
By the way is there a trick to get rid of the strange borders?
Thanks, Andreas.
offrench
It works... but you have to make sure the color profile is set to linear, otherwise the objects do not line up with the displaced surface correctly. Thanks for pointing me to the right direction!
As for the edge artifacts, just resize your displacement map to 1.002 and they should disappear.
I have written a short tutorial on this.
Kretschi
offrench wrote:It works... but you have to make sure the color profile is set to linear, otherwise the objects do not line up with the displaced surface correctly. Thanks for pointing me to the right direction!
Thanks for the tutorial!
jeremyshin
I am sorry to reOpen the subject but I have an additional question to this.
I have plane (400 x 6000 cm) with a texture that has displacement on it. I have transformed my texture trough the c4d texture tag to be able to tile it and keeping the displacement to tile too.
But when I input the displacement map on the Scatter Position parameter it doesnt allow me to transform it (tile it basically) as I did in the texture tap of my plane.
Anybody had any hint about that ?
jeremyshin wrote:I am sorry to reOpen the subject but I have an additional question to this.
Don't put displacement but texture that's connected to displacement. And ply with translate.y parameter.
djs01
Colour Profile isn't available in the scatter position shader to change to linear.
Version 3.07-R2 Mac (can't upgrade either as Cuda/GPUs aren't found)
Return to “User requests”
