Cinema 4D version 2018.1.1-R2 (Obsolete stable) - 19.04.2019
Iceman9
My biggest complaint over the past year...and I've posted about it before...is that something in the plugin repeatedly changes or resets values under the 'Octane Settings'. Seems to happen when switching tabs or opening/closing settings window. Happens a lot.
Sometimes clicking around in the program will even change kernels. Other times it turns the Response back to SRGB after I've set it (repeatedly) to Linear. And using Presets doesn't really help. Often it won't remember or re-set to the Preset that I have configured.
I can understand bugs happen with CUDA or with changes from Maxon, etc. And I know there is a LOT of complexity in this software and a lot for the devs to dig through. But frankly this issue just seems amateurish.
Kalua
Iceman9 wrote:My biggest complaint over the past year...and I've posted about it before...is that something in the plugin repeatedly changes or resets values under the 'Octane Settings'. Seems to happen when switching tabs or opening/closing settings window. Happens a lot.
I think this used to be often back in older versions. Nowadays I see this type of behavior restricted to the denoiser tab every time I reboot C4D.
I also think that the fact that this kind of bug doesn't happen to everyone makes it harder to the developers to track down it's cause and solution.
Octane User since V1 Beta
natemac00
"use steal" in Render Setting doesn't seem to be taking. I still need to go into the "Network Preferences" and click "Steal" on each individual computer.
______________
Nate Mac - Chicago, IL
Cinema 4D R26.107 | Octane 2021.1.6
Main: AMD ThreadRipper | Win10 | 32-core | 128GB | RTX A5000 & GTX 2070 SUPER
Slaves: 4x GTX 980 Ti | GTX 1080 | GTX 1070 | GTX 1070Ti
BCres
Just upgraded one of my V4 licenses to 2018.1 Enterprise.
May be a dumb question...but how do you install the remote render license? Is there a separate installer? Thanks.
**Nevermind figured it out**
If you don't know, you have to have enterprise, then just use the same installer and run client on the remote after installing the program.
Could you please kindly share some video to show how you obtain this issue? I never get this problem. Also select all log options and send c4doctanelog.txt from the session.
Iceman9
I'll try to find time to record/gather this.
YYP
Critical_Log
[08:36:29] CRITICAL: Duplicate definition for net.maxonexample.cinema4dsdk
[object_impl.cpp(4477)]
[08:37:04] CRITICAL: Stop: This is not allowed, invoking call needs to be fixed. [xstring_impl.cpp(489)]
I had this problem opening a new project
error .png (10.77 KiB) Viewed 5951 times
YYP wrote:Critical_Log
Not sure It's an Octane plugin issue. What do you have as plugins?
YYP
Need to delete some plugins?I won't have this problem with version 4.04
YYP
In the morning the version of 2018.1.2 was done :lol: thank
Return to “Releases”
