NVIDIA 418.81 breaks Octane (FIXED 419.17 / 4.02/2018.1 RC2)
Locked
Seun116_1
New Nvidia update finally works with Octane!
jwlovell
Goldorak wrote:NVIDIA 418.81 driver (Feb. 4th) doesn't work with Octane - please don't update yet! We are working with NVIDIA to fix ASAP. We need to recompile Octane 4/2018.1+ to work with this driver version, and will post an update to this thread once that is done and confirmed working. Thank you!
If you have updated to this driver, here is how to revert: viewtopic.php?p=356426#p356426
419 is out as of today. Hope that fixes this. It's breaking my other iray apps
DoctorJellybean
Hmm, the 419.17 update doesn't seem to work for me (1080 Ti and DAZ Studio Plugin). It works when reverting back to 417.71
DoctorJellybean
I didn't see that there is a DAZ Studio plugin update (4.02.1.44), the updated NVIDIA drivers do work with that installed.
TRRazor
Sorry, but no, it doesn't.
I just updated to 419.17 and get the following error, upon opening the render viewport:
21:04:11.494: +++++ Plugin running.
21:18:46.133: CUDA error 999 on device 0: unknown error
21:18:46.133: -> failed to link file
21:18:46.133: device 0: failed to load OSL shader code: error : Multiple definition of 'cuSptStatistics' in 'cuda_texturenode', first defined in 'snippets_internal'
21:18:46.133: device 0: failed to compile module 0
21:18:46.138: CUDA error 999 on device 1: unknown error
21:18:46.138: -> failed to link file
21:18:46.139: device 1: failed to load OSL shader code: error : Multiple definition of 'cuSptStatistics' in 'cuda_texturenode', first defined in 'snippets_internal'
21:18:46.139: device 1: failed to compile module 0
21:18:46.157: Render engine failure occured! (WARNING)
21:18:53.728: Render engine failure occured! (WARNING)
W10 64 bit | i7 3770K | MSI Geforce RTX 2080 (8GB) + GTX Titan Black (6GB) | 32 GB DDR3 RAM
DoctorJellybean
Just updated to 419.17 and get the following error, upon opening the render viewport:
Did you update the DS plugin (4.02.1.44)?
cadmiumred
I'm experiencing this same error using OctaneRender 4.01.1 Standalone. Today's Nvidia update (419.17) appears to not fix the issue.
mojave
Hi everyone,
Just letting you all know that the latest driver 419.17 fixes the issue with Octane that the series 418 used to have.
Please make sure your plugin or standalone is using the following versions of the Octane core:
- Stable 4.02 or newer (there will also be a new v3 release soon)
- Experimental 2018.1 RC2 or newer.
Thank you.
hpeskobar
417 work fine then I update to 418 fail. waited 7 days ... gave up re install 417 took forever . octane work fine....
updated to 419.17
Now I get this................. ( c4d)
Started logging on 23.02.19 04:54:49
OctaneRender Studio 4.01.1 (4010100)
1hr Later im back to 417 and everything oks fine now.
but STILL NO FIX
nuno1980
hpeskobar wrote:417 work fine then I update to 418 fail. waited 7 days ... gave up re install 417 took forever . octane work fine....
updated to 419.17
but STILL NO FIX
You have OR v4.01.1 but @Mojave said minimum v4.02 or newer version only... loool
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute ;)
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ACER Predator XB273U F5 27" :D
Locked
