OctaneRender™ 4.0 for LightWave™ - Beta build 4.00.0.16 RC6
Happy to read that
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10
Net render : MB Asus Pro WS W790E-SAGE SE - XEON - 128GB - 2 x RTX 3090 - 3 x RTX 2080TI
- sauloarruda
Hi All,
I was testing this last version. And I found something strange. When rendering the reflection passes, It is rendering without any color information. I am attaching a scene for testing.
Is this a bug?
Saulo
Is this a bug?
Saulo
- Scene.rar
- (9.8 KiB) Downloaded 247 times
- FrankPooleFloating
Hey Juanjo, when you answer the above, could you also answer if that is your stuff in the LWCAD Gallery? There are some pretty sweet renders in there, that have Juan J Gonzales on them, and I was wondering if that was you... If it is, I think it is safe to say that all pistons are firing on both sides of your brain. Nice.
- rustyippolito
Can we please get an ETA on the next build with UDIM support? Our use of Substance Painter is causing need for a huge amount of UV maps to cover our models and UDIM would help SO MUCH in organizing the mess of multiple surfaces using multiple UV maps. Please advise:)
Hi,sauloarruda wrote:Hi All,
Is this a bug?
Saulo
This behavior sounds good to me. The red color comes from the diffuse component, not from the reflection. In the glossy material, the reflection color comes from the specular parameter.
Yes, I've been working as architecture and visualization artist for a long time before working full time as software developerFrankPooleFloating wrote:Hey Juanjo, when you answer the above, could you also answer if that is your stuff in the LWCAD Gallery? There are some pretty sweet renders in there, that have Juan J Gonzales on them, and I was wondering if that was you... If it is, I think it is safe to say that all pistons are firing on both sides of your brain. Nice.
Some of my old projects made more than ten years ago
https://www.dropbox.com/s/rdma7kh3r7z9z ... n.pdf?dl=0
https://www.dropbox.com/s/9l6i07xrcduoi ... 0.pdf?dl=0
https://www.dropbox.com/s/jf2jsz5ltianq ... 8.pdf?dl=0
I'm working on it right now. I'll release a new plugin build as soon as the new Octane core (probably the final 4.00 one) is ready, probably this week.rustyippolito wrote:Can we please get an ETA on the next build with UDIM support? Our use of Substance Painter is causing need for a huge amount of UV maps to cover our models and UDIM would help SO MUCH in organizing the mess of multiple surfaces using multiple UV maps. Please advise:)
- sauloarruda
thanks Juanjo! With your explanation makes sense to me now.
