what about main tab?FxDesign wrote: No I did'nt change the render settings of octane, or xparticles. Here is a screenshot, do you need my scene too ?
Version 4.0-RC7-R4 (obsolete release candidate) 10.11.2018
I've changed nothing here tooaoktar wrote:what about main tab?FxDesign wrote: No I did'nt change the render settings of octane, or xparticles. Here is a screenshot, do you need my scene too ?
I think I need your scene to check.FxDesign wrote:Hello Aoktar,
I'm in a situation where the render in the live viewer is different than the picture viewer.
Let me explain
With Xparticles, I'm emitting particles from a shader, then I'm meshing these particles with an Ovdbmesher.
I'm using the vertex color tag in the diffuse to have the vdb colored. In the LV no problem, but in the final render, the Ovbmesher has no color.
Here is a preview of my workflow. Can you tell if I'm doing something wrong ?
Thank you
- imnotjiminy
Hey there! I have a big issue on the latest releases of 4.0.
The kind of projects i make are usually of around 900 frames, that on preview, render at around 6 seconds each. But when i send to render the whole sequence, it takes around 4 more seconds to start procesing every frame. So it grows the render time like crazy.
The first 4.0 beta got rid of that problem and every frame rendered super fast. The render time stated in the info bar at the bottom of the render was the actual time shown at the end of the frame on the "history" of the picture render. Every render was actually shown rendered on 6 seconds, but now they are shown rendererd on 10 seconds even tho according to the info bar at the bottom it was rendered in 6.
I'm i being clear? That's something that i NEED and would LOVE to see fixed soon
Mind to send me your scene for investigating for a quick solution? Just PM me by forum messaging.imnotjiminy wrote:Hey there! I have a big issue on the latest releases of 4.0.
- teeshiiddo
Is it possible for C4D to remember which GPU is selected for Denoising? So I can pick GTX card instead or RTX.
My RTX cards have an issue when Denoising the first frame of a scene ( reported to beppe ).
Asus X99 10G WS | Windows 10.0 | 6x GTX 1080 Ti + 2x 2080Ti | i7-6850K CPU @ 3.60GHz | 32GB RAM
The numbers you see that are about rendering session after scene preparation. Other than this plugin and octane core spends some extra time to process scene data.aoktar wrote:Mind to send me your scene for investigating for a quick solution? Just PM me by forum messaging.imnotjiminy wrote:Hey there! I have a big issue on the latest releases of 4.0.
Having cuda 700 crashes when using displacement node and various projection types. Seems to be intermittent.
Plenty of VRAM, PSU is fine, latest drivers, no overclocking.
Scene attached.
Scene attached.
- Displacement 700.zip
- (87.72 KiB) Downloaded 264 times
TDR?tim_grove wrote:Having cuda 700 crashes when using displacement node and various projection types. Seems to be intermittent.
Scene attached.
Testing the "Displacement 700" file. I also can get the cuda 700 or Cinema 4D crash. The way to make it crash quickly for me is I have my Octane layout that has the IPR active, the Node editor showing the nodes and the material preview showing. Then do an octane render to the picture viewer. Then the picture viewer will fail or going back to the IPR will fail.
