From rhino material to octanematerial
fabrizio_s
is there a way to transform rhino materials to octane materials?
bye
Hi Fabrizio
Rightclick the Rhino material in the Material tab->Change Type to Octane material.
Or you can convert all Rhino materials to Octane materials with the Setup tree rightclick menu->Convert All Rhino Materials to Octane Materials.
fabrizio_s
Hi Paul,
I can't find it. Am I looking for it in the wrong place?
Bendbox
Hi Fabrizio,
I'm assuming you're in Rhino 6 if you don't see it on the right click. If so, it's located here under the main material editor. Just click on the pull down menu and select "Octane Material" and it will change the Rhino material to an Octane material.
Also, one other note . . . if you decide to convert all materials to octane materials by right clicking in the Octane Settings tree, the only materials it will convert are ones that are used. Just FYI.
Win10x64 / AMD Ryzen 9 5900X / 64g RAM / 2 x RTX 3090
fabrizio_s
thanx!
frisog
Hi there, when I try to convert a materials with the 2 options available, all the material colors and textures are lost.. is this a know issue? (transparency is converted correctly)
This is with the newest Rhino and newest Octane plugin (4.5.0.111) for Rhino 6 (Version 6 SR17 - (6.17.19218.13231, 08/06/2019).
I don't completely understand what you are saying. Can you provide some screenshots of the problem please?
frisog
Sure. See attached image with explanation in the image.
Rhino to Octane material problems
frisog
Hi Paul, any idea on the what the issue could be?
Hi. I just tested this, and changing the type via the material combo box, and using the Convert All Materials To Octane Materials resulted in the same material conversion, so it is working correctly for me. I notice on your screenshot there are no texturemaps, so there are no maps to convert to the Octane material. If you have a specific material which demonstrates the problem you are having, can you please send it to me and I will take a closer look.
Return to “Rhinoceros 3D”
