OctaneRender® for 3ds max® v4.00-RC7 - 6.09 [OBSOLETE]
I feel the material editor navigation is slower now compared to 3.07 where I come from. I work with the "classic" one. Not node-based. It's on all scenes. Feels a bit laggy.
PURE3D Visualisierungen
- paride4331
Hi dartfrog,DartFrog wrote:Stuck on "SCENE EVALUATION" on a scene with an un-textured sphere. Basically the same problem as 6.08
OctaneRender 4.00 RC7
Plugin 6.09
Geforce 416.34
Cuda 10
I'd send the scene but it's literally just a sphere in nothing without Render Layer checked.
Is there any chance you could set your OctaneRender viewport on "denoised beauty"?
So after restarting 3dsmax (2018) It will render a sphere, teapot, etc. Something simple. When I open up a more complex scene, it does not render. And I don't see any bar graphs or numbers for texture compression. I tried turning off the persistence settings, tried denoise pass, didn't work. It may be worth noting that once I "break" it, it won't render the simple scene any more. I'd have to shut down max.Hi dartfrog,
Which is the recommended Nvidia driver in terms of speed and stability for Octane4?
I use 388.71
I use 388.71
- paride4331
Hi mbetke,mbetke wrote:I feel the material editor navigation is slower now compared to 3.07 where I come from. I work with the "classic" one. Not node-based. It's on all scenes. Feels a bit laggy.
did you check options in Render setup > Tools > Open Octane Global Preferences > material?
- paride4331
Hi DartFrog,DartFrog wrote:So after restarting 3dsmax (2018) It will render a sphere, teapot, etc. Something simple. When I open up a more complex scene, it does not render. And I don't see any bar graphs or numbers for texture compression. I tried turning off the persistence settings, tried denoise pass, didn't work. It may be worth noting that once I "break" it, it won't render the simple scene any more. I'd have to shut down max.Hi dartfrog,
I think it depends on texture compression which is very slow, could you try testing with this scene?
https://we.tl/t-hTs1zChs31
It looks like this. I use settings from a dev who posted here some days ago.Hi mbetke,
- paride4331
Hi mbetke,mbetke wrote:It looks like this. I use settings from a dev who posted here some days ago.Hi mbetke,
I see. Have you this issue using RC4?
