OctaneRender® for 3ds max® v4.00-RC7 - 6.09 [OBSOLETE]
coilbook
It looks like ai lights work fine now. We are using itoo forest objects to generate on top of pflow particles. I am not sure what the problem was.
mbetke
I feel the material editor navigation is slower now compared to 3.07 where I come from. I work with the "classic" one. Not node-based. It's on all scenes. Feels a bit laggy.
PURE3D Visualisierungen
coilbook
mbetke wrote:I feel the material editor navigation is slower now compared to 3.07 where I come from. I work with the "classic" one. Not node-based. It's on all scenes. Feels a bit laggy.
I agree. It got faster and now back to slow again.
paride4331
DartFrog wrote:Stuck on "SCENE EVALUATION" on a scene with an un-textured sphere. Basically the same problem as 6.08
OctaneRender 4.00 RC7
Plugin 6.09
Geforce 416.34
Cuda 10
I'd send the scene but it's literally just a sphere in nothing without Render Layer checked.
Hi dartfrog,
Is there any chance you could set your OctaneRender viewport on "denoised beauty"?
DartFrog
Hi dartfrog,
So after restarting 3dsmax (2018) It will render a sphere, teapot, etc. Something simple. When I open up a more complex scene, it does not render. And I don't see any bar graphs or numbers for texture compression. I tried turning off the persistence settings, tried denoise pass, didn't work. It may be worth noting that once I "break" it, it won't render the simple scene any more. I'd have to shut down max.
mbetke
Which is the recommended Nvidia driver in terms of speed and stability for Octane4?
I use 388.71
paride4331
Hi mbetke,
did you check options in Render setup > Tools > Open Octane Global Preferences > material?
paride4331
DartFrog wrote:
Hi dartfrog,
Hi DartFrog,
I think it depends on texture compression which is very slow, could you try testing with this scene?
https://we.tl/t-hTs1zChs31
mbetke
Hi mbetke,
It looks like this. I use settings from a dev who posted here some days ago.
paride4331
mbetke wrote:
Hi mbetke,
Hi mbetke,
I see. Have you this issue using RC4?
Return to “Releases”
