Version 3.08.3 (obsolete stable)
Forums: Version 3.08.3 (obsolete stable)
Moderator: aoktar
Re: Version 3.08.3 (latest stable)
Postby tomsvfx » Mon Aug 20, 2018 7:28 am
tomsvfx Mon Aug 20, 2018 7:28 am
It renders out from PV also like this, I tried different variations of changing linear/tonemapped, exr compressions etc... and nothing changed. So its not a problem in settings.
tomsvfx
Postby thanulee » Mon Aug 20, 2018 11:02 am
thanulee Mon Aug 20, 2018 11:02 am
Sorry im not on a pc atm to check. Im saying this cause i ve seen stuff in lv that are jagged but when i open images in AE are fine. Maybe too obvious but did u try to save those out via PV and open em in nuke/ae?
i7 3930K | 2 x GTX 980 ti 6gb | 32GB RAM | Corsair Carbide 540
R18 | win 10 home
thanulee
Postby aoktar » Mon Aug 20, 2018 6:37 pm
aoktar Mon Aug 20, 2018 6:37 pm
thanulee wrote:Sorry im not on a pc atm to check. Im saying this cause i ve seen stuff in lv that are jagged but when i open images in AE are fine. Maybe too obvious but did u try to save those out via PV and open em in nuke/ae?
Yes correct.
Postby thanulee » Tue Aug 21, 2018 11:49 am
thanulee Tue Aug 21, 2018 11:49 am
Hi i use a c4d noise with displacer. When i add same noise in octane material, is not on same place as displacer. In standard render they align correct. How do i fix this?
thanks
Scene file: https://www.dropbox.com/s/yryd4j5fys3jj ... m.c4d?dl=0
R18 | win 10 home
thanulee
Postby GSMATTAnimation » Tue Aug 21, 2018 12:37 pm
GSMATTAnimation Tue Aug 21, 2018 12:37 pm
Does anyone have the link to download Octane Render Stand Alone 3.8.3 please? I can't find it in the download section. Trying to search for it in the forum gives a common search error.
GSMATTAnimation
Postby BCres » Tue Aug 21, 2018 12:47 pm
BCres Tue Aug 21, 2018 12:47 pm
GSMATT,
It is here:
viewtopic.php?f=24&t=68494
And if for some reason that doesn work, the link is actually in the very post in this thread...about midway down.
I didn't see it either and ended up posting in this thread about a problem with networking. Abstrax pointed me in the right direction.
Hope this helps.
BCres
Postby aoktar » Tue Aug 21, 2018 1:37 pm
aoktar Tue Aug 21, 2018 1:37 pm
thanulee wrote:Hi i use a c4d noise with displacer. When i add same noise in octane material, is not on same place as displacer. In standard render they align correct. How do i fix this?
thanks
displacer match problem.rar
(156 KiB) Downloaded 29 times
Postby thanulee » Tue Aug 21, 2018 1:50 pm
thanulee Tue Aug 21, 2018 1:50 pm
thanks
Thanks a lot!!!
R18 | win 10 home
thanulee
Re: Version 3.08.3 (latest stable) Problem with LBSH
Postby martinzip » Thu Aug 23, 2018 2:09 pm
martinzip Thu Aug 23, 2018 2:09 pm
Dear Ahmet
I have a serious problem in composing the shadow layer when I light a scene with an hdri.
The shadow does not get "clean". For example I have these trees on Render Layer 2 and the background shape object
studio on render layer 1. In the shadow layer I should see only the shadows from the trees... but I see also a kind of selfshadow of the studio object ...
When I turn out the hdri I have only the shadows from the additionla lights in the scene and the shadow alpha is clean...but than I can not profit from hdri lightning ..hey ??
I am working on mac 10.12.6. octane 3.803
Please help. Kind regards from cologne
Martin
Renderlayer trees
Renderlayer LBSH with hdri enviroment lightning
Renderlayer LBSH hdri turned off
martinzip
Postby martinzip » Thu Aug 23, 2018 2:15 pm
martinzip Thu Aug 23, 2018 2:15 pm
Ok I solved it... I turned off the Importance sampling ...than the shadows have a clean alpha ...
Is it a bug or a user knowledge problem ...
Martin
martinzip
PreviousNext
Return to Releases
Users browsing this forum: Majestic-12 [Bot] and 5 guests
Sat Jan 18, 2020 5:56 am [ UTC ]
