Version 3.08.3 (obsolete stable)
tomsvfx
It renders out from PV also like this, I tried different variations of changing linear/tonemapped, exr compressions etc... and nothing changed. So its not a problem in settings.
thanulee
Sorry im not on a pc atm to check. Im saying this cause i ve seen stuff in lv that are jagged but when i open images in AE are fine. Maybe too obvious but did u try to save those out via PV and open em in nuke/ae?
thanulee wrote:Sorry im not on a pc atm to check. Im saying this cause i ve seen stuff in lv that are jagged but when i open images in AE are fine. Maybe too obvious but did u try to save those out via PV and open em in nuke/ae?
Yes correct.
thanulee
Hi i use a c4d noise with displacer. When i add same noise in octane material, is not on same place as displacer. In standard render they align correct. How do i fix this?
thanks
Scene file: https://www.dropbox.com/s/yryd4j5fys3jj ... m.c4d?dl=0
GSMATTAnimation
Does anyone have the link to download Octane Render Stand Alone 3.8.3 please? I can't find it in the download section. Trying to search for it in the forum gives a common search error.
BCres
GSMATT,
It is here:
viewtopic.php?f=24&t=68494
And if for some reason that doesn work, the link is actually in the very post in this thread...about midway down.
I didn't see it either and ended up posting in this thread about a problem with networking. Abstrax pointed me in the right direction.
Hope this helps.
thanulee wrote:Hi i use a c4d noise with displacer. When i add same noise in octane material, is not on same place as displacer. In standard render they align correct. How do i fix this?
thanks
displacer match problem.rar
(156 KiB) Downloaded 320 times
thanulee
thanks
Thanks a lot!!!
martinzip
Dear Ahmet
I have a serious problem in composing the shadow layer when I light a scene with an hdri.
The shadow does not get "clean". For example I have these trees on Render Layer 2 and the background shape object
studio on render layer 1. In the shadow layer I should see only the shadows from the trees... but I see also a kind of selfshadow of the studio object ...
When I turn out the hdri I have only the shadows from the additionla lights in the scene and the shadow alpha is clean...but than I can not profit from hdri lightning ..hey ??
I am working on mac 10.12.6. octane 3.803
Please help. Kind regards from cologne
Martin
Renderlayer trees
Renderlayer trees
Renderlayer LBSH with hdri enviroment lightning
Renderlayer LBSH hdri turned off
martinzip
Ok I solved it... I turned off the Importance sampling ...than the shadows have a clean alpha ...
Is it a bug or a user knowledge problem ...
Martin
Return to “Releases”
