OctaneRender V4 XB2.1
Interfaces
Hi, I use the script Ol' Ready Cam. I test with V4
it does not work !
I 'd like to use it with denoising to divide computing time
viewtopic.php?f=73&t=41365
Thanks for your help
coilbook
Hi this was done in 3d. Anyway to have paint shader added to the Toon shader where we can set brush strokes ,edges, etc ? So it can look like this. Thanks
roeland
Jolbertoquini wrote:Hi Vijay and Dev Team,
I was trying OSL round edges and I get a error :
"<node 'OSL texture'>:98: error: Unsupported feature: trace()
<node 'OSL texture'>:99: error: unsupported signature for getmessage: only getmessage("baking", key, value) is supported, where key is a string literal.
No, there are no plans to support the trace() function.
Hesekiel2517
Hey there,
are ai lights already working? I tried a scene with 3 small lights. Octane 3 and Octane 4 without AI Lights are much faster than Octane 4 with AI Lights. Am i doing something wrong?
Octane 3
1000 Samples 5,47 Minutes
Octane 4
same settings 7.30 Minutes
funk
I noticed that if I enable the denoiser render passes, then select them, I get a GPU failure error. I dont have the denoiser enabled in cuda devices or the imager, but I dont think it should cause a failure.
Jolbertoquini
coilbook wrote:Hi this was done in 3d. Anyway to have paint shader added to the Toon shader where we can set brush strokes ,edges, etc ? So it can look like this. Thanks
Hi There,
Try to use the matcap osl this would give you this look by creating the matcap for it. I did some effects like that by mixing the shaders or create my on custom version you can mix with toon shader to get a extra look.
Cheers,
JO
viewtopic.php?f=33&t=67688
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
vijay
funk wrote:I noticed that if I enable the denoiser render passes, then select them, I get a GPU failure error. I dont have the denoiser enabled in cuda devices or the imager, but I dont think it should cause a failure.
Thanks for the bug report. This will be fixed in the next release
barokt
When i try to install my computer i get this error.
I have regular Licence what is the problem?
pegot
V4 XB2.1 is an old test build. That, and the newer Release Candidates, generally run for only around 120 days or so I think. You can download the latest Release Candidate (RC 7) from here:
viewtopic.php?f=33&t=69243
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
