Materias Slot sooo slow pease any tips?
I wonder if there is any way to improve the refresh of the material slot as it is sooo slow compared to competitors..I mean reay annoying and I have a decent spec both GPU and CPU ( 2 x 1070 - i7 6850K 32GB )
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
same here. When I choose a material it takes 10-20 seconds sometimes to update or go through material options. It seems that octane 1.5 and even 2 was faster with material update and I have new titan xp pascal just for UI and it is not used for rendering.justix wrote:I wonder if there is any way to improve the refresh of the material slot as it is sooo slow compared to competitors..I mean reay annoying and I have a decent spec both GPU and CPU ( 2 x 1070 - i7 6850K 32GB )
- paride4331
paride4331 wrote:Hi,
what I could recommend is to try like this.
it still feels slow. Opening material dialog and waiting 5-10 seconds to update. Clicking on material waiting 3-4 seconds for it to show settings, going through sub materials like mix same story. .I am using old fashion compact material i9-7900x, nvme and titan Xp I thought this should fly through
Same goues on this side..no much of improvement and I'm on a i7-6850K and dual 1070 ..an that should fl indeed..coilbook wrote:paride4331 wrote:Hi,
i have the same problem on a 7 x GTX1070 system...super super slow MAT EDITOR
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
- paride4331
Hi guys,
I'm sorry about material editor issue, because it does not seem to happen in my case.
could you try this?:
1) connect your less performing graphics card to monitors, then 3dsMax> Render> Render Setup> Devide (tab)> inactivate that graphics card and apply.
2) try like in the screenshot.
Get back to you if anything changes, I would like to better understand this issue.
Hi Paride,paride4331 wrote:Hi guys,
here is a little video I will send you the scene and try your method. Step one wont work since the PC has 2 titans Xp
- mat ed.MOV
- (1.76 MiB) Downloaded 4362 times
Paride your suggestions.."kinda" work...but now we have to click in the shader for it to update...and as soon as we do that..slow update
- paride4331
Hi Nildoe,
sure your right, my suggestion was not a workaround, but an attempt to understand what could cause this issue,
Coilbook shows issues using Multi/Sub-Object; is that issue with Multi/Sub-Object for you too?
