Materias Slot sooo slow pease any tips?
justix
I wonder if there is any way to improve the refresh of the material slot as it is sooo slow compared to competitors..I mean reay annoying and I have a decent spec both GPU and CPU ( 2 x 1070 - i7 6850K 32GB )
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
coilbook
justix wrote:I wonder if there is any way to improve the refresh of the material slot as it is sooo slow compared to competitors..I mean reay annoying and I have a decent spec both GPU and CPU ( 2 x 1070 - i7 6850K 32GB )
same here. When I choose a material it takes 10-20 seconds sometimes to update or go through material options. It seems that octane 1.5 and even 2 was faster with material update and I have new titan xp pascal just for UI and it is not used for rendering.
paride4331
what I could recommend is to try like this.
coilbook
paride4331 wrote:Hi,
it still feels slow. Opening material dialog and waiting 5-10 seconds to update. Clicking on material waiting 3-4 seconds for it to show settings, going through sub materials like mix same story. .I am using old fashion compact material i9-7900x, nvme and titan Xp I thought this should fly through
justix
Same goues on this side..no much of improvement and I'm on a i7-6850K and dual 1070 ..an that should fl indeed..
nildoe
i have the same problem on a 7 x GTX1070 system...super super slow MAT EDITOR :(
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
paride4331
Hi guys,
I'm sorry about material editor issue, because it does not seem to happen in my case.
could you try this?:
1) connect your less performing graphics card to monitors, then 3dsMax> Render> Render Setup> Devide (tab)> inactivate that graphics card and apply.
2) try like in the screenshot.
Get back to you if anything changes, I would like to better understand this issue.
coilbook
paride4331 wrote:Hi guys,
Hi Paride,
here is a little video I will send you the scene and try your method. Step one wont work since the PC has 2 titans Xp
mat ed.MOV
(1.76 MiB) Downloaded 4362 times
nildoe
Paride your suggestions.."kinda" work...but now we have to click in the shader for it to update...and as soon as we do that..slow update
paride4331
Hi Nildoe,
sure your right, my suggestion was not a workaround, but an attempt to understand what could cause this issue,
Coilbook shows issues using Multi/Sub-Object; is that issue with Multi/Sub-Object for you too?
Return to “Autodesk 3Ds Max”
