Thanks to Hayssam Keilany for sharing this OSL.
OSL Texture Tiling shader
- paride4331
- tiling_texture.zip
- (2.89 MiB) Downloaded 1484 times
Kind of magic ! Thanks for sharing !
- paride4331
to get help, you could try in Octane C4D forumanklove wrote:Thank you, i find it very useful, but i prefer cinema 4d, can you explain how you created it, like the node screenshot or so?
- no-tile.orbx
- (3.03 MiB) Downloaded 754 times
ORBX is fine, thanks!paride4331 wrote:to get help, you could try in Octane C4D forumanklove wrote:Thank you, i find it very useful, but i prefer cinema 4d, can you explain how you created it, like the node screenshot or so?
i7 10700k | Win 10 64 bit | RTX 3090
- paride4331
Hi Rik,Rik wrote:Paride
Please can you save the max file as release 14?
Can't get the OSL to do anything.
Here it is
- (2.85 MiB) Downloaded 622 times
Thanks for the file Paride
Finally got round to experimenting with it. Works well on my grass field but couldn't get the OSL texture to make any displacement even though it linked in OK to the disp material. Is that right?
I used my regular displacement map in this example but I don't think the tiling is particularly noticeable. Good enough for today's deadline anyway!
PS not sure why the image looks so dark here, looks much lighter in the render window. Suspect it's something to do with the unfathomable gamma confusion.
- paride4331
Hi Rik,
you would use baking texture node to work with displacement map.
Gamma seems to be working well; this is my basic setting, but you could set response sRGB with gamma 1.
- tiling_texture_disp.zip
- (825.68 KiB) Downloaded 407 times
