OSL Texture Tiling shader
paride4331
Thanks to Hayssam Keilany for sharing this OSL.
tiling_texture.zip
(2.89 MiB) Downloaded 1515 times
HHbomb
Kind of magic ! Thanks for sharing ! :D
anklove
Thank you, i find it very useful, but i prefer cinema 4d, can you explain how you created it, like the node screenshot or so?
i7 10700k | Win 10 64 bit | RTX 3090
paride4331
anklove wrote:Thank you, i find it very useful, but i prefer cinema 4d, can you explain how you created it, like the node screenshot or so?
to get help, you could try in Octane C4D forum
no-tile.orbx
(3.03 MiB) Downloaded 798 times
anklove
ORBX is fine, thanks!
Rik
Please can you save the max file as release 14?
Can't get the OSL to do anything.
paride4331
Rik wrote:Paride
Hi Rik,
Here it is
tiling_texture.zip
(2.85 MiB) Downloaded 648 times
Rik
Thanks for the file Paride
Finally got round to experimenting with it. Works well on my grass field but couldn't get the OSL texture to make any displacement even though it linked in OK to the disp material. Is that right?
I used my regular displacement map in this example but I don't think the tiling is particularly noticeable. Good enough for today's deadline anyway!
PS not sure why the image looks so dark here, looks much lighter in the render window. Suspect it's something to do with the unfathomable gamma confusion.
paride4331
Hi Rik,
you would use baking texture node to work with displacement map.
Gamma seems to be working well; this is my basic setting, but you could set response sRGB with gamma 1.
tiling_texture_disp.zip
(825.68 KiB) Downloaded 428 times
Rik
Thanks. Looks great. will have a play once this deadline's done, assuming win 10 doesn't crash again :o
Return to “Autodesk 3Ds Max”
