rhino obj export and material nodes
SamPage
waterthinking wrote:do you think I can install the v5 obj exporter on the v4 version if I get a hand on it? would it work just replacing the .rhp file that's on the rhino4 plugin folder?
I just tired copying the V5 32 bit export_OBJ.rhp to the V4 plug-ins folder this morning and it doesn't seem to work. The plug-in loads, but when you try and export you get an error exporting file message. I'll ask the McNeelies about it, but they seem to be pretty done on the idea of updating V4.
Sam
Win 7 64bit | 2x GTX 285 | i7 920 | ASUS P6T Deluxe | 12GB
radiance
do you think it would help you if i created a rhino exporter in the plugins category forum sampage ?
Radiance
SamPage
radiance wrote:do you think it would help you if i created a rhino exporter in the plugins category forum sampage ?
I would find it handy :)
radiance
here you go ;)
Radiance
justix
waterthinking wrote:hi sam,
thanks for dropping by,
I upload the whole thing again; here you are, the thing simplified. 3 layers, 3 materials,
octane 2.2b; but happens also with 2.3 pre's
nvidia 258.96 drivers
cuda 3.1 toolkit
windows 7 32
rhino 4 sr8
tried all obj export settings. nothing worked so far
hope you got a clue!
HI mate, just to let you know that I'm on the same boat, it's really seems that Rhino 5 can do the job just right, I did update Rhino 4 obj exporter recently becaue there is a new version http://wiki.mcneel.com/labs/objio but it does issue few things except this one... :(
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
blade_master7
Hi Waterthinking,
I'm not sure if you've resolved your problem, so if you have ignore this post. I imported your file into Moi3D. The model came in fine. I'm not sure how you exported, but there was some interesting geometry in the 3DM. I cleaned it up, renamed the objects and imported into Octane with Triangles only.
See the attached images, and I've attached the Obj file as well. If you need a hand with conversion let me know.
Kind Regards
Charles'
kitchenObj.zip
Converted Obj file.
(28.96 KiB) Downloaded 463 times
Object file imported into Octane.
Original 3DM file imported into Moi3d.
se77e
sorry for my English but I write from Italy and use a translator
I use rhino4 and I had the same problem waterthinking
hundreds of nodes! :shock:
I solved it in these days. is necessary to divide rhino objects into mesh and uniting them into material groups
In this way everything works and I can finally import my models in octane ;)
Asus P6T, Intel i7 950, 12Gb Ram, MSI GTX 470 1280, Windows 7 64Bit
maarres
Hello se77e,
I meet the same problem, but i'm not sure to understand your procedure:
What do you mean with " uniting them into material groups"? with layers?
Thank you :D
Daniel79
this proble was solved few days a go...see the end of this topic:
http://www.refractivesoftware.com/forum ... =41&t=5952
SORRY, MY ENGLISH IS BAD!
2 Xeon quad core E5440_8gb Ram_Nvidia GeForce 2GTX 780ti 3Gb/Nvidia Quadro K2000_Win10 64bit_Octane 3.02_Rhinoceros3D
tom_holly
I've uploaded a script to remove and sort the duplicate materials in MTL files when exporting OBJ files from Rhino 3D.
It works for Rhino 4. It may or may not work for other versions.
This is not fully tested, so use at your own risk.
You may post any bugs to me here: http://www.refractivesoftware.com/forum ... =41&t=7044
http://rhino-3d-obj-mtl-fix.zzl.org/
Cheers, Tom
AMD Athlon(tm) II X4 640 @ 3.0 HGz | 4.00 GB | Octane beta 2.44 | Rhino V4 SR9 | Windows Vista x64 | GTX 570
Return to “Rhinoceros 3D”
