Multi Input Nodes
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
tobydalsgaard
When using the following nodes in the diffuse channel of a material there is a hard line that splits the top and bottom of the live viewer where there is a color/gamma shift:
Add Node
Multiply Node
Mix Texture Node
Gradient Node
Test 1
Test 1
Test 2
Test 2
OTOY_BugReport_MultiTextureLiveViewerError.zip
Test Project
(92.78 KiB) Downloaded 173 times
This does not not show up in the final render, only the live viewer.
Windows 10, 1703 OS Build: 15063.413
4x 1080ti EVGA Founders Edition
64 GB Ram
Nvidia Drivers: 382.33
OctaneRender 3.08_test6
C4d Octane Render Plugin 3.08_test6
No extra information from Octane Log file.
tobydalsgaard
Also in the roughness channel
Hi tobydalsgaard,
do you mind to to try without the HDRI Link plugin?
ciao beppe
tobydalsgaard
I tried without HDRI Link and had the same issue, even with just a single light in the scene.
Right now it only seems to be acting up when I use netrender and have one of those nodes attached.
tobydalsgaard wrote:I tried without HDRI Link and had the same issue, even with just a single light in the scene.
Textures in netrender is broken on 3.08-test6. I'll have to move this topic because it's about a test version and no need for confusion to users. Thanks for reporting this anyway!
tegatwork
Same problem here...
Return to “Bug Reports”
