ies light rays
darkline
I know this has probably been asked but I've searched and cannot find an answer. I can see how fog/volume light works with daylight environment but I'm simply using a hdri environment and 2 octane lights. I do not want both lights to have volume light, just one IES light. How do I apply this in 3dsmax? There is no 'medium' node on the ies light.
Windows 7 64bit/ Intel 3930K/ ASUS Rampage IV/ GTX980ti x 2/ 64GB system RAM
paride4331
Hi darkline,
You can not use a medium node in an IES light at present.
This is a work around:
viewtopic.php?f=27&t=60532&p=310174#p310174
jim99
Please add IES light to work with medium node in future updates, I have seen C4d octane plugin does it, we are hoping you could bring 3dsmax
plugin to the same level as well... :|
paride4331
Hi Jim99,
Can you kindly share a link or screenshot with IES and integrated medium node in C4D please?
jim99
Hi Paride,
https://www.youtube.com/watch?v=Tv9j3ki ... e=youtu.be
AT 41:30 he switched light to IES light also added in cloud effect to the medium, looks like done by noise texture.
Cheers
J
paride4331
Hi Jim99,
Octane 3dsMax IES lights work exactly the same way (screenshot)
All 3dsMax Octane lights and blackbody / texture emission work with medium volume.
viewtopic.php?f=21&t=56599&p=290400&hil ... ys#p290400
Integrated medium in IES would be something like this:
And this does not even have in C4D for all I know.
jim99
Hi Paride,
Could you please upload this demo file in max2016 format? I must be doing something wrong.
J
paride4331
Hi jim99,
here it is.
01c.zip
(99.67 KiB) Downloaded 284 times
pixelcan
If used in a moving camera: make the box with the scattering material large and place it just "inside" the camera view (a couple of cm). Link it to the camera and make sure it covers whatever light that will be passing through it. This will get rid of any clipping issues.
pixelcan
One issue I'm having with this volume light technique is the hard and visible noise around the light-sources. Have been playing with most of the settings but even oversampling a lot still gives me way too much noise. Any ideas of how to reduce or smooth this noise in the render (not post) would be greatly appreciated!
BTW, happy new year everyone! :)
Return to “Autodesk 3Ds Max”
