Hi guys,
new istance range node (3.07 SDK)
Istance range node 3dMax
- paride4331
thanks. Would be nice to have instance on subobject level of one object.paride4331 wrote:Hi guys,
Also please add an option to lock dirt texture to subobject level so objects near it wont create more dirt on it (for example, more dirt on the bottom of the wheel (with dirt texture) because it touches the ground)
Hi , Paride. Using instance range I have strange artifacts. Bug or not bug ?
- OCT_pb_instrange.zip
- (39.43 KiB) Downloaded 666 times
- paride4331
Hi Rik,
meanwhile attach file test, I hope they help you.
- 01-random.zip
- (749.04 KiB) Downloaded 621 times
- 02-gradient.zip
- (748.98 KiB) Downloaded 674 times
- paride4331
Hi HHbomb,
here for you,
here for you,
- (41.64 KiB) Downloaded 629 times
Thanks.
Nothing was changing until I turned the octane proxy tick off then on again. Is this a feature?
Still don't know what's going on though.
What's maximum id in the instance map? What number does it represent?
What should the start and stop be in the oct obj properties? Is it related to the number of objects the material is applied to?
Buggered if I can see me getting instances of proxy trees with random colours on leaves and random variations across the different instances of those proxy trees.
- paride4331
paride do you write istance on purpose, cause I see it's written as iNstance in the user interface - you did that on every picture and text as well?
3dmax, zbrush, UE
//Behance profile //BOONAR
