Hi Aoktar. I found some strange octane behavior on cloner instances with random color node. In Live Viewer i can see white color, but when i starts Render View i see red color on instance. Why is this happening?
GTX 680 4 Gb ram, Win 8.1, 16Gb ram, Octane 3.07-R1, Cinema 4d R18.057
Incorrect color on Cloner with random color node
C. RAM Capacity (i.e. 6 GB)
I attach test scene.
- Test.rar
- (102.16 KiB) Downloaded 238 times
Please try on latest builds.
Hi divasoft,
I have opened and rendered your scene as it was, but I have the same result in both LV and PV: Did you followed the instructions in the readme.txt file for a correct installation?
ciao beppe
ciao beppe
Yes, sure. I followed the instructions.
We cannot reproduce what you reported. Also it's interesting that you have a problem like this. Because randomcolors will work fine on render instances on every cases. Try it with "All movable" option in PV.
what is the PV? Where can i find "all movable"?
Picturw Viewer. You can find in octane render setting->geometry engine.divasoft wrote:what is the PV? Where can i find "all movable"?
