Version 3.07-R2 (previous stable) update on 01.11.2017
Forums: Version 3.07-R2 (previous stable) update on 01.11.2017
Moderator: aoktar
Re: Version 3.07-R2 (Stable) update on 30.10.2017 - Two bugs
Postby aoktar » Wed Nov 01, 2017 5:01 am
aoktar Wed Nov 01, 2017 5:01 am
BCres wrote:2. When exporting to an .orbx file via the LV menu, NO FILE is ever written to the hard drive. I tested this on R18 and R19 and several different drives. I can't make .orbx animated files now in C4D.
Hope you can fix these. Thanks.
I haven't changed any codes here. It's working on my side. How could i reproduce it?
Re: Version 3.07-R2 (Stable) update on 01.11.2017
Postby aoktar » Wed Nov 01, 2017 7:11 am
aoktar Wed Nov 01, 2017 7:11 am
I've fixed R2 built for HDR rotation issue. Needs to be downloaded again. Sorry for problem!
Postby BCres » Wed Nov 01, 2017 12:13 pm
BCres Wed Nov 01, 2017 12:13 pm
aoktar,
I just installed 3.07-R2 and it the .orbx file exporting is again working properly (I was on R1 when I posted the error a few posts back.)
Please disregard my error report above. And thank you for all of your amazing work.
BC
BCres
Postby eyeonestudio » Wed Nov 01, 2017 1:51 pm
eyeonestudio Wed Nov 01, 2017 1:51 pm
R2 01.11.2017
Specular Map Slot?
CINEMA 4D R23 / 10GbE Network(SFP)
Master(1ea) : Win10, AMD3990X, 256GB RAM, 1080Ti*1, RTX3090*3
Slave (1ea) : Win10, AMD1950X, 64GB RAM, RTX3090*2
Slave (2ea) : Win10, INTEL4930K, 64GB RAM, RTX3090*2
eyeonestudio
Postby aoktar » Wed Nov 01, 2017 1:56 pm
aoktar Wed Nov 01, 2017 1:56 pm
eyeonestudio wrote:R2 01.11.2017
Specular Map Slot?
Uhm sorry! I forgot to remove it that's for 3.08. Just ignore it, i'll fix on next build.
Postby VVG » Fri Nov 03, 2017 5:09 pm
VVG Fri Nov 03, 2017 5:09 pm
i found few problems
1. Forester parametric tree creates a leak of RAM, if you make an editable object - everything is fine (maybe Forester not supported)
2. floor and octanetag with a smooth appearance leads to a crash
3. In Picture viewer shows network rendering, although it is not active
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, EVGA GTX 1080Ti + 1070
Octane-for-C4D(R23.110)2020.15.x, Ent 2020.1.5, Cycles4D. Nvidia 456.71 STUDIO
VVG
Postby BCres » Sat Nov 04, 2017 11:09 am
BCres Sat Nov 04, 2017 11:09 am
Sorry to hear about the Forester problem creeping up again. But I can confirm something has been going on with Forester in these last few Octane versions—serious memory errors that would cause my system to shutdown. It worked great on 3.06.
I had even traded emails with the developers at 3D Quakers suspecting it was their new version (1.2.3) but traced the problem down to Octane. It was the Octane 3.07.test3 beta. Once i moved to 3.07.test6 beta the problem vanished. I won't be able to test 3.07 - R2 until next week but I'll report back then. I hope it's not back, I use Forester a lot.
Also, about #3, aoktar has added a bind all check box in the Octane render. Have you tried that?
BCres
Postby aoktar » Sat Nov 04, 2017 11:17 am
aoktar Sat Nov 04, 2017 11:17 am
VVG wrote:i found few problems
Could you please post scenes for forester and floor problems?
Postby VVG » Sat Nov 04, 2017 8:39 pm
VVG Sat Nov 04, 2017 8:39 pm
aoktar,
add in Scatter the automatic addition of Mograph effectors if you select scatter (as in the clone / matrix)
thanks!
VVG
Postby VVG » Sat Nov 04, 2017 8:42 pm
VVG Sat Nov 04, 2017 8:42 pm
BCres wrote:Also, about #3, aoktar has added a bind all check box in the Octane render. Have you tried that?
maybe I missed something? can explain me
VVG
PreviousNext
Return to Releases
Mon Jan 25, 2021 1:42 pm [ UTC ]
