uvset problem
furladan
Hello there!
I have a problem in Standalone with generated uvset from Modo saving orbx file.
uvset MODO
uvset MODO
uvset STANDALONE
uvset STANDALONE
I use last Standalone release and last version of Modo Plugin
Here scene files:
NovaHawkOctane.zip
uv set problem scene files
(31.07 MiB) Downloaded 206 times
I hope you can help me,
Marco
Win10 / i7 3930K 6x3,2 Ghz / 32GB Ram / GTX TITAN + GTX 780Ti + GTX 1080Ti
The Foundry Modo, Octane Render plugin
Hi Marco. What version of the plugin are you using pls? What process did you use to export from Modo to ORBX?
furladan
Hi Paul,
my version is 3.07.0.125
My process is:
- open octanerender viewport
- save to ocs or orbx format
thanks
Thanks for providing that scene. I think this is happening because the OBJ file format that is used to save the geometry in the scene does not support multiple UV sets. You can instead set the Scene->Current Range end frame to 1 and use the octane.saveAnimation command, which will save the geometry to ABC rather than OBJ format, and it will render correctly in Octane Standalone.
furladan
ok, done.
uvset work properly with generated abc by script, now. Thanks Paul!
But there was another problem... camera coordinates are wrong.
I used the generated camera by old orbx file to bypass the problem.
furladan
Hi Paul,
Bepeg4d understood the problem of the camera coordinates.
My camera was panoramic. This generates coordinates problem.
To solve it, i set thinlens in Modo and change it to panoramic in standalone.
thanks to all!
Return to “Foundry Modo”
