Hey there,
when i use more than one Float Input in the Nodegraph no more input appears in the Schematic. Is it possible to feed more inputvalues in the Nodegraph?
Thanks in advance
Multiple Float Inputs in Nodegraph
If you add Input nodes into the NodeGraph, they will be automatically added to the schematic when you close the NodeGraph window.
- Hesekiel2517
Hey Paul,
i know
But i want to input multiple values of the same kind. So if you add another Float Input it won't appear in the Nodegraphnode. Is it possible to change this?
i know
Try renaming one of the float input nodes in the nodegraph. Duplicate channel names are not allowed on Modo Schematic nodes.
- Hesekiel2517
Next Problem is I get a CUDA Error 700...
Can you send me that scene pls? I cannot tell from the screenshot what is in the nodegraph node.
- Hesekiel2517
I made a little video and a testscene. If you tire it with the last 3.6 Version this error does not occur.
- Error_700.zip
- (8.83 MiB) Downloaded 218 times
This is an Octane error - which I have now reported to Otoy. Appears to be related to overlapping gradient values.
