Multiple Float Inputs in Nodegraph
Hesekiel2517
Hey there,
when i use more than one Float Input in the Nodegraph no more input appears in the Schematic. Is it possible to feed more inputvalues in the Nodegraph?
Thanks in advance
If you add Input nodes into the NodeGraph, they will be automatically added to the schematic when you close the NodeGraph window.
Hesekiel2517
Hey Paul,
i know :-)
But i want to input multiple values of the same kind. So if you add another Float Input it won't appear in the Nodegraphnode. Is it possible to change this?
Try renaming one of the float input nodes in the nodegraph. Duplicate channel names are not allowed on Modo Schematic nodes.
Hesekiel2517
Ahh! Thank you, that works!
Hesekiel2517
Next Problem is I get a CUDA Error 700...
Can you send me that scene pls? I cannot tell from the screenshot what is in the nodegraph node.
Hesekiel2517
I made a little video and a testscene. If you tire it with the last 3.6 Version this error does not occur.
Error_700.zip
(8.83 MiB) Downloaded 223 times
This is an Octane error - which I have now reported to Otoy. Appears to be related to overlapping gradient values.
Hesekiel2517
Ahh ok. Thanks for your effort!
Return to “Foundry Modo”
