I'm trying to export a very simple model from rhino into octane and I'm getting a huge amount of material nodes. It looks like every single polysurface in rhino gets it's own material. I've made a search in the forums for export settings from rhino and tried all kind of settings in the obj export options (also downloaded the more advanced import/export plugin from mcneel), to no avail. What am I doing wrong? Also been playing with diferent kind of material assignements within rhino, but nothing changed.
Can someone help -I'm in a deadline-?
Here's a screenshot of the problem and the model itself (erased nearly everything and still getting nearly 30 mat.)
My config: windows 7 32, octane 2.2b, rhino 4 sr8, geforce gtx 460
Thanks in advance
Pd. would like to avoid, if possible, the blender route someone pointed out
rhino obj export and material nodes
- waterthinking
- kitchen.zip
- compressed rhino file
- (258.47 KiB) Downloaded 523 times
- waterthinking
hi Henrik,
what do you mean by checking colors in grouping method? Do I have to make groups before exporting?
Yesterday I tried exporting through blender and, allthough I got it working, it is a useless method considering my normal workflow, in wich I modify geometry and go back and forth..
- waterthinking
Is the geometry exported alright?
A wild guess is that all this nodes are surface styles you have at startup.
I have configurated my projets with only one color and put on new colors as I need new materials.
can you post a screenshot of your modell
maybe im on a another planet,but i had simular problems in the beginning
Asus p67|Windows 10|GTX970_GTX1070|i7-2600K|16GBRAM
| FormZ|C4D
| FormZ|C4D
- waterthinking
hi henrik,
the nodes you see read as various materials that repeat themselves. regarding the export, I tried countless different setups, I even started a new file with very simple boxes and got to the conclusion every single box got it's own node/material, even if I only have 1 material in the scene. I also tried making all boxes the same color, same layer, same everything, to no avail.
I finally presented the thing without the renders, as octane would constantly crash working with so many nodes, and exporting through blender was quite a nightmare and had problems with smoothing groups. will try to post on the plugin forum, and see if I have better luck.
Anyway, thanks for your support!
- waterthinking
hi Henrik,
Here is an obj file of 3 boxes on the same layer with the same material.
So I get 3 nodes within octane ???
- waterthinking
ok.. here's the file with the mlt
- 3boxes.zip
- (3.58 KiB) Downloaded 541 times
