C4D R16 constant crashing w/ Octane
echolock
Just tested using an older version (3.05.1) and the same crash happens.
Send me a PM for a teamviewer connection if you mind that. Let's check directly.
echolock
I can confirm that the crash happens on both my machines. The aforementioned Mac Pro and my MacBook Pro Retina 15". Same actions, same crash happens.
Cinema 4D R16.050
Octane C4D plugin 3.06.2
(OctaneVR 3.06.4 Mac standalone app is also installed)
Macbook Pro Retina 15 inch
2.5Ghz Intel Core i7
16GB RAM
Intel Iris Pro
macOS 10.12.3 (Sierra)
OXIDE
Same here with R18
I updated my GTX drivers and i thought i fixed it somehow but after a day it returned.
Arash
I also get constant crashing (windows 10/ Cinema 4D R18/ latest GTX driver).
Hi Arash,
it seems that latest Nvidia drivers are not very stable with CUDA.
Please, perform a clean installation of 382.05 drivers or similar, if possible.
ciao beppe
tony_acrid
Hello, need help
Also getting a crash with the same scene which were rendering fine few weeks ago.
One frame renders ok, next one starts and after I get an fast black screen (probable my Nvidia Gtx1060 turns off) and Cinema crashes.
Reinstalled nvdia drivers as written above, ver 382.05 installed right now, nothing changed
Bugreport attached.
Please help, I am kinda in a rush on this project.
(Win7, Cinema 4D r18, nvidia gtx1060)
_BugReport.txt
(273.36 KiB) Downloaded 339 times
Hi tony_acrid,
from your bugreport, the Nvidia drivers installed are 372.70 (372.70), so please, perform a clean installation of 382.05 drivers:
ciao beppe
tony_acrid
Just checked evertything again. Cinema4d crashs without writting bugreport, thats why I sent an old one.
For now I reinstalled 385 drivers with clean installation.
After crash I got an text in Cinema - Octane failed, check octane log
Here is it -
Started logging on 26.08.17 19:44:45
OctaneVR 3.06.2 (3060200)
CUDA error 100 on device -1: no CUDA-capable device is detected
-> failed to initialise CUDA driver API
Scene created in plugin version -1
I attached the printscreen, so you can see that Octade have rendered few frames just fine.
I tryed different Octane render settings, just getting the same crash, but if I make the quality higher it could render not 4 frames before crash, but only 2-3..
Temperature of my GTX1060 is ok, about 70-72 degrees.
tony_acrid wrote:Just checked evertything again. Cinema4d crashs without writting bugreport, thats why I sent an old one.
Here is it -
You may have a corrupted graphic card. Or alternatively try some older drivers.
Return to “OctaneVR Questions & Discussion”
